Author Topic: float tool ??  (Read 3531 times)
float tool ??
« on: February 16, 2007, 07:48:06 PM »
so does anyone know where to buy one of those tools for measureing float height . cant seem to find one on ebay or google
(man i type slow sheesh)
Offline doug_id
    • My Cafe 550 Project Gallery
Re: float tool ??
« Reply #1 on: February 16, 2007, 08:06:08 PM »
I think if you search the threads here you will find a few ways to make your own.   If memory serves me anyway.   ::)
02 Concours
78 CB550
06 Stella 150 2t Scooter
Offline Bob Wessner
  • "Carbs Suck!"
Re: float tool ??
« Reply #2 on: February 17, 2007, 02:35:29 AM »
Or, try your local hardware store. I found a small metal, sliding T-ruler. It measured inches on one side and MM on the other, it was only about $2.50 as I recall.
Offline puppytrax
Re: float tool ??
« Reply #3 on: February 17, 2007, 03:38:19 AM »
Yes - Sears has them, so did my Ace Hardware store. Has both Inch & Metric scales.   ;)
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline mcpuffett
Re: float tool ??
« Reply #4 on: February 17, 2007, 04:36:39 AM »
you can also use a tape measure  ;)  mick.
USN20
Re: float tool ??
« Reply #5 on: February 17, 2007, 04:58:19 AM »
Having just finished setting the floats on my '74 CB750, the T-ruler works great and is cheap.
Using the T-ruler: http://www.salocal.com/sohc/tech/carb/asmpg_mgs/flthgt.htm
The more expensive options are:
The Honda tool number is: 07401-0010000
Aftermarket:  http://www.z1enterprises.com/detail.aspx?ID=1486
Ebay:  http://cgi.ebay.com/ebaymotors/Honda-orig-N-O-S-carburetor-float-level-gauge-CB-750_W0QQitemZ300082070209QQihZ020QQcategoryZ35597QQrdZ1QQcmdZViewItem
Re: float tool ??
« Reply #6 on: February 17, 2007, 09:27:44 AM »
thanx alot for the input fellas , i figured there was a way around buying the $40 tool
i didnt even think of the slide rule idea , thats what i'll do i think
Offline starion88esir
Re: float tool ??
« Reply #7 on: February 17, 2007, 09:58:14 AM »
The lip on the carbs is compensated for on the Honda carb tool is it not? The little "L" appears to be just the right height and would compensate for the fact you're supposed to measure from the carb gasket surface.  Or am I just wrong?
71 CB175 - next project
76 CB750F - current project
Offline Einyodeler
  • Midnight bugs taste best!!!
Re: float tool ??
« Reply #8 on: February 17, 2007, 10:27:45 AM »
You measure from the lip itself , not the gasket.  ;)
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Re: float tool ??
« Reply #9 on: February 17, 2007, 10:31:30 AM »
I've heard gasket surface on numerous occasions. :shrugs:
It just seemed to make sense. They need to specify this stuff!
Heironymous Josh
Re: float tool ??
« Reply #10 on: February 17, 2007, 11:11:46 AM »
You know, I'm not afraid to admit when I don't understand something and I still don't understand the float height deal.  My manual recommends 14.5 mm float height.  Do I need to measure with the carbs sitting the way they would on the bike, upside down?  Something about "just touching float valve"  Am I measuring the free play or the maximum distance it will drop down.  Do I measure from the end of the float furthest from the arm and pin or near the arm and pin???
Re: float tool ??
« Reply #11 on: February 17, 2007, 11:44:13 AM »
you are measureing where the float "floats" just before it engages the float valve
kettlesd
Re: float tool ??
« Reply #12 on: February 17, 2007, 04:50:42 PM »
Lay the carbs upside down with the floats facing up - block it so its level. Very gently lower the floats onto the float needles so they just make contact , but do not compress them.
Offline crazypj
  • I'm brill, me
Re: float tool ??
« Reply #13 on: February 17, 2007, 11:18:32 PM »
Honda says to tilt carbs about 70 degrees so contact is made but damper spring is not compressed
PJ
Heironymous Josh
Re: float tool ??
« Reply #14 on: February 18, 2007, 01:30:07 PM »
I think I've got it.  My confusion was in what portion of the float to adjust.  I'm assuming you are to bend the small arm that pushes on the float valve so that it is just touching (but not engaging) while the float is at the designated height.  The other "arm" that determines the ultimate play of the float is what confused me.  Does this need to be adjusted as well?  As I have them now, the floats will hang quite a bit lower than the spec number but the float makes contact with the float valve right at the designated height.  Should I raise them up so that the only play they have is the few millimeters between contact and engaging of valve?
Re: float tool ??
« Reply #15 on: February 20, 2007, 02:53:06 PM »
no it will be"floating" in gas
rebelbob
Re: float tool ??
« Reply #16 on: August 11, 2010, 12:14:21 PM »
Exactly where do you measure when setting the float level on a 1971 CB750K?is it from the base under the bowl gasket or from the top of the lip or inside the notch on the lip?
Offline Scott S
Re: float tool ??
« Reply #17 on: August 11, 2010, 12:29:50 PM »
 Read this: http://www.salocal.com/sohc/tech/carb/asmpg_mgs/flthgt.htm
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline gravano
Re: float tool ??
« Reply #18 on: August 11, 2010, 12:46:26 PM »
I put a red mark on an old credit card at the spec height of my float, and measure that way.
Fits nicely in the pocket.
Re: float tool ??
« Reply #19 on: August 11, 2010, 12:47:33 PM »
I put a red mark on an old credit card at the spec height of my float.
i made one out of my wifes credit card  :P
Re: float tool ??
« Reply #20 on: August 11, 2010, 12:52:29 PM »
PJ
+1
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
Re: float tool ??
« Reply #21 on: August 11, 2010, 04:53:26 PM »
I don't remember who it was that posted it, but I remember somebody on this board contributed this.
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline ev0lve
Re: float tool ??
« Reply #22 on: August 11, 2010, 05:34:44 PM »
+1
http://forums.sohc4.net/index.php?topic=25423.msg262282
I suppose the only question is whether you can still find a floppy disk here in the 21st century - cardboard? ;D
Offline Frostyboy
  • Circa 1951
Re: float tool ??
« Reply #23 on: August 11, 2010, 05:43:30 PM »
Heh heh heh. You're right of course Iggy. I have heaps of em, I'm not game to dispose of 'em, I forget what's on 'em & my floppy drive died ages ago.
Thanks for finding the original post.
We haven't met yet.
[CB550F1]
