PM sent:-)
http://forums.sohc4.net/index.php?topic=93998.0
I followed the link; very interesting.
This is not relevant to the 400F, but interesting ...
After reading the post I decided to - for no particular reason - decided to check out the situation on the 750K2. Interestingly, and complete news to me, CMS show that after engine number 1014995 only inlet valve seals are required. DSS don’t seem to register that at all.
When I rebuilt my engine 231*** a couple of years ago, I put in 8 seals, so since my engine is a K4 engine – it’s the one that came with the bike, or at least was with the bike when I got it in ‘78 – I checked on a 750K4 (USA) parts fiche. This says:
“K0” up to 1014995 has 8 seals - as per CMS; exhaust valve guide P/N is 12027-300-310
“K0” & K1 1014996 to 2000000 have 4 seals; exhaust valve guide P/N is 12027-300-320
K2, K3 & K4 after that are back to 8 seals; exhaust valve guide P/N is 12027-300-330
Inlet valve guide stays the same throughout; 12025-300-00.
Of academic interest to most I suppose, but the message is clearly, make sure you are using the right parts fiche and check P/N against the engine number.
