Author Topic: CB550K Air-assist forks - keep or ditch?  (Read 1455 times)
Offline the nick
« on: September 07, 2020, 06:01:23 PM »
Hi y’all!
I have a 1978 CB550K. The previous owner had installed air-assist fork tube caps, the type with an equalizer tube running between each cap. In my shakedown runs I have been rolling with about 6-8PSI in the forks (via bike pump) as recommended in other threads. My understanding was that with NO pressure they should act as stock forks. In my case, the forks are almost acceptable with air, BUT with no pressure, the forks bottom out on the slightest bump.
That is not normal/expected behavior, is it?
I’m set to do my fork seals and replace the fork oil this week. I imagine a lot of discovery will happen in this process. I suspect this problem is due to low fork oil and/or blown or leaky seals. Does that track?
Should I move forward with the air caps or just replace with OEM style and call it a day?
Thanks!
Nick
Offline scunny
  • don't call me expert
Re: CB550K Air-assist forks - keep or ditch?
« Reply #1 on: September 07, 2020, 08:53:26 PM »
Replace your fork seals and oil, run the air assist caps and then decide.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline jonda500
« Reply #2 on: September 07, 2020, 11:27:36 PM »
Unless you are extremely heavy, no. Fork oil will help, but only somewhat..
John
A starter clutch thread:
Offline the nick
« Reply #3 on: September 08, 2020, 08:19:13 PM »
That’s what I figured. I’m about 200lbs, so nothing too crazy. Going with 10W fork oil this time around and “EZ” fork seals. I’ll try with the existing caps on, but I fear their seals may also be shot.
Thanks y’all!
Now just to find a new rear wheel  ::)
« Reply #4 on: September 08, 2020, 08:26:34 PM »
check your springs when you do the seals.  The manual specifies a free length and they were kinda ssoft even when new.  If you are bottomimg out frequently, that is a spring rate problem.
Offline the nick
« Reply #5 on: September 09, 2020, 04:32:09 PM »
Thanks for the tip, Sean. Will definitely do so. Got ‘em apart right now and so far everything looks ok so far. The air caps are a bit brittle under closer inspection, I may just ditch ‘em.
« Reply #6 on: September 09, 2020, 06:19:03 PM »
Most of these bikes have sacked-out front springs, too. The best way to check this is: bike on centerstand, lift the front wheel off the ground via the handlebars, let it settle back down (at the 'top' of their current height) and watch how far down they compress with the empty bike. If it is more than 3/4" then the springs need to be shimmed. Then, up under prop the engine so the forks are just off the ground, remove the fork caps, and see where the tops of the springs are sitting: if the springs are below the threads inside the fork tubes (they probably are) then shim back to between 1/3 and 1/2 the thread length using either short pieces of cut off pipe or stacks of large washers, or even cut off PVC pipe (I think 1/2" pipe fits?) pieces. When you install the caps, you should just be able to catch the first 2 threads when starting in the fork caps.
Oftne the aftermarket air fork cap kits applied NO shim length, so as to fit many forks. This meant that simply installing them made the forks worse off than they were with the solid caps. That's why I recommend drilling and tapping the existing caps for some threaded Schraeder valves, which will show up in my next book.
Offline the nick
« Reply #7 on: September 10, 2020, 08:07:47 PM »
THANK YOU sir!
I just finished the fork refurb today. Both springs measured 469mm, did not reveal any threads, and required firm pressure to seat the fork tube bolts and thread them in. According to my Clymer manual, this measurement is far above even the stock 450mm length and far above the 425mm “replace” bottom limit. I’m pretty surprised, as the previous owner had commuted daily 75mi on the bike and had to be at least 300lbs. Perhaps the air forks saved the springs but trashed the seals?
Unsurprisingly, I pulled 150cc of fork oil from both forks combined. And each fork drained a different color of dirty oil!
The air caps are indeed the good kind - they appear as old as the bike and appear to be OEM bolts drilled and tapped for Schrader valves with an equalizer tube between them.
I may still try PVC pre-load shims, depending on how the bike rides. I’m still waiting on my wheels from the shop, so it’ll be a wait and see situation. Looking forward to experimenting!
Thanks!
Nick
« Reply #8 on: September 10, 2020, 08:42:41 PM »
10 W oil seems light.. to me anyway.  We used to use ATF a lot ..
Offline robvangulik
  • Honda Fourever
« Reply #9 on: September 11, 2020, 03:01:28 AM »
+1 on ATF, but ATF and power steering is 10W too and so is most hydraulic oil.
Offline the nick
« Reply #10 on: September 11, 2020, 05:55:04 PM »
I used Amsoil Shock Therapy “Medium #10”. Amsoil says it is closest to 10W, but not exactly 10. Not gonna lie, it’s what was available at the local shop - mostly Harley baggers up here in Northern MI, and that’s what the shops cater to.
The Amsoil website lists equivalents as follows:
Spectro SK400
Maxima Fork Oil 10
Ohlins #15
Spectro Fork Oil 10W
Redline Medium
If I’ve erred too light, I’m game to change it out. Still got 5 days til the wheels go on anyway!
Offline Erny
« Reply #11 on: September 12, 2020, 12:31:47 AM »
THANK YOU sir!
Thanks!
Nick
About spring length - do not 100% trust Clymer! Only trustable source is official Honda service manual, bur even this have some typo errors.
There were several types of forks for 500/550 from K0 to K3. I had the same pb with spring length with my 550K1.
Even Honda service manual did not provide correct info. Finally I found it by chance combining manuals from 500/550K four and 500T.
If I rmemeber well there is some thread about it here on forum
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
