Author Topic: 350/4 question about the side covers  (Read 670 times)
Offline wolf550
« on: September 10, 2020, 07:47:46 PM »
So I'm working on a set of the 350/4 side covers.
casting has come out good on the first try.
at the bottom where that screw lock mechanism goes into the hole I had some over fill of the aluminum.
Since I am not going to get a 350 frame to check this out my questions are:
does the circle area of the bottom tab slide into something circular on the frame or does the frame just bump up to the inside of the circle tab? do I have to remove the over fill of these bottom tabs or can I leave it be?
thanks in advance
74' CB550 (Sold)
71' CB500/550 (Sold)
Offline carnivorous chicken
Re: 350/4 question about the side covers
« Reply #1 on: September 11, 2020, 07:21:08 AM »
That looks great! And they will work just fine.
On the back side of the locking mechanism the bolt protrudes about 1-1/4 - 1-1/2" with a spring, so they don't actually fit snugly into anything on the frame.
Offline wolf550
« Reply #2 on: September 11, 2020, 08:32:23 AM »
awesome!
getting a drill into areas likr ghat is always a pain in the butt to drill!
74' CB550 (Sold)
