Author Topic: Replacing main 8-pin plug when the wire is too short: CB750 K5  (Read 976 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: September 19, 2020, 11:13:30 AM »
My old 8-pin plug from my alternator on my CB750 was falling apart, so I replaced it; but now the wire is too short. Was having a great ride yesterday when the ignition started acting all weird and I can see that the yellow, white & light green/red wires have all pulled out. So what's the proper fix here? Cut the whole thing off and solder new, longer wires to the old? I looked in the Tips section but didn't see anything...
Re: Replacing main 8-pin plug when the wire is too short: CB750 K5
« Reply #1 on: September 19, 2020, 12:10:13 PM »
Did you bend out the tangs on each connector before putting in the new connector plug? If the wires worked with your older one, depending on what all you did, they should work with the new one. Any wire cutting/shortening yet?
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #2 on: September 19, 2020, 12:19:23 PM »
I cut the old spades and female bits off to install new. That made the whole thing ~1” shorter, and it’s too tight behind the air box. Wires pulled out of new spades, which are still in the plug.
« Reply #3 on: September 19, 2020, 01:07:12 PM »
That did make it too short for sure. If you can't change the routing to give the extra length then yes you'll have to splice in wire to make it correct.
Online madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #4 on: September 19, 2020, 02:09:25 PM »
A new alternator sub harness can be had pretty cheap:
https://4into1.com/alternator-wire-harness-31110-300-154-cb750-1969-1978/
https://www.amazon.com/Alternator-Wire-Harness-31110-300-154-1969-1978/dp/B01N52EMO8
I know hindsight is 20/20, but I always cut the old connectors right at the connector to keep the loss of length to within a 1/4". The sub harness linked above is rather inexpensive, but I've never used one so I can't vouch for quality.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #5 on: September 20, 2020, 12:09:16 AM »
Both my bikes have got new harness, but from Yamiya.
Maybe same...
New harness to oil pressure sensor too, the old had really hsrd plastic cover over sensor.
