Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
How did you figure out there wasn't oil in the sump? Was it shipped without oil in the bike?(over seas shipping companies usually require no oil or gas in bikes). Maybe if you had it shipped to you and prepped that they didn't start the bike but only put oil in the oil tank??Your oil light goes out is a good indicator you have oil pressure. Remove a valve adjuster cap to see if you have oil flow to the top end.
Quote from: newday777 on September 20, 2020, 05:46:48 amHow did you figure out there wasn't oil in the sump? Was it shipped without oil in the bike?(over seas shipping companies usually require no oil or gas in bikes). Maybe if you had it shipped to you and prepped that they didn't start the bike but only put oil in the oil tank??Your oil light goes out is a good indicator you have oil pressure. Remove a valve adjuster cap to see if you have oil flow to the top end.I bought the bike locally. When I wanted to change the oil, nothing came out. So fire up the bike with a valve cap off?
Quote from: jebon on September 20, 2020, 05:54:24 amQuote from: newday777 on September 20, 2020, 05:46:48 amHow did you figure out there wasn't oil in the sump? Was it shipped without oil in the bike?(over seas shipping companies usually require no oil or gas in bikes). Maybe if you had it shipped to you and prepped that they didn't start the bike but only put oil in the oil tank??Your oil light goes out is a good indicator you have oil pressure. Remove a valve adjuster cap to see if you have oil flow to the top end.I bought the bike locally. When I wanted to change the oil, nothing came out. So fire up the bike with a valve cap off?First, kill switch off, spark plugs out and spin over with the starter to observe oil flow to the top end.
Good to hear you have flow. Yes you should see some bubbles and movement in the tank when running.
Quote from: newday777 on September 20, 2020, 06:34:56 amGood to hear you have flow. Yes you should see some bubbles and movement in the tank when running.Just took it for a very short ride (1 min)When I got back I had white smoke from 1 and 4
Quote from: jebon on September 20, 2020, 07:33:04 amQuote from: newday777 on September 20, 2020, 06:34:56 amGood to hear you have flow. Yes you should see some bubbles and movement in the tank when running.Just took it for a very short ride (1 min)When I got back I had white smoke from 1 and 4 Any further results to update?
Quote from: newday777 on January 22, 2021, 10:27:21 amQuote from: jebon on September 20, 2020, 07:33:04 amQuote from: newday777 on September 20, 2020, 06:34:56 amGood to hear you have flow. Yes you should see some bubbles and movement in the tank when running.Just took it for a very short ride (1 min)When I got back I had white smoke from 1 and 4 Any further results to update? Looks like the engine is apart for a rebuild and paint. Current thread going on now. http://forums.sohc4.net/index.php/topic,185069.0.html
