Author Topic: Oil Light came on while riding  (Read 10250 times)
Online bryanj
Re: Oil Light came on while riding
« Reply #25 on: September 22, 2020, 01:12:18 AM »
Cant view links on the system i have, if the screen was clean how did the debris get into the pump as all that between screen and pump is cast oilways!
Offline jakec
« Reply #26 on: September 22, 2020, 01:49:57 AM »
That’s what I was thinking.
« Last Edit: September 22, 2020, 01:51:30 AM by jakec »
1970 CB750 K0
1977 CB750 Chop
1984 Big Twin Evo Chop
1997 XR650L
Online bryanj
« Reply #27 on: September 22, 2020, 06:58:08 AM »
Still say engine out and full strip/clean. You MUST find what that debris is/was and remove all of it before assessing what you need to replace
Offline jakec
« Reply #28 on: September 22, 2020, 09:39:37 AM »
If I strip the engine and I lost an oil ring, I need new piston set 0.5 over, clean the engine, some new gaskets, will I need to bore again?
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline minimo
« Reply #29 on: September 22, 2020, 09:45:48 AM »
You’ll have to inspect the cylinder sleeves to assess if there’s any damage to the surface. It’s likely your rings got mangled in there, and yes, running it further ain’t gonna make it better.
Engine rebuild time.
Offline jakec
« Reply #30 on: September 22, 2020, 10:47:58 AM »
If I rebuilt the engine again, what would I even do to prevent this from happening again? The only reason I used cruzin image pistons was because it's impossible to get oversized genuine Honda. The more I think about this the more I want to just put the bike in the back of the garage for 20 years.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #31 on: September 22, 2020, 10:49:15 AM »
Until you open it up no one will know 'for sure' until you inspect it. Ring destruction will generally always require boring and or new sleeve.
https://www.dynoman.net/engine/pistons/hondaSleeves.html
« Reply #32 on: September 22, 2020, 10:51:44 AM »
Don't give up.....
https://www.dynoman.net/engine/pistons/dp-CB550.html
« Reply #33 on: September 22, 2020, 12:16:23 PM »
Get an inspection camera in there, look around.. can probably do a leakdown test.
 Good Luck..
Offline Nurse Julie
« Reply #34 on: September 22, 2020, 01:06:12 PM »
What a bummer, that's a real shame. Having looked at your pic of the oil pump, wow, there sure is some broken metal there, also, why is the gerator not fitting flush in the pump?. My view on it would be that its glass bead from the vapour blasting that started all that destruction, fine enough to get through the pick up screen but acted as grinding paste around the engine. It will be interesting to see what the crank/ gearbox/  camshaft etc look like.
Trust me I'm a Nurse, I promise it won't hurt....much
Online bryanj
« Reply #35 on: September 22, 2020, 01:35:48 PM »
Thats why i asked if it had been blasted
Offline jakec
« Reply #36 on: September 22, 2020, 01:45:44 PM »
It is blasted but don’t you think that would cause small particles, not large ones? Also I was very thorough about cleaning the parts after blasting.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline minimo
« Reply #37 on: September 22, 2020, 03:26:53 PM »
But, did you blow out all of the oil passages amid the cleaning? I think that’s what the others are getting at
Offline jakec
« Reply #38 on: September 22, 2020, 03:59:49 PM »
Yes. Air compressor, then pressure washer followed by air compressor again. definitely focused on the oil galleries
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #39 on: September 22, 2020, 05:02:52 PM »
Is there needle rollers in the oils pump ? Maybe a roller came apart. . Debris looks like some bigger piece chopped up real small. Hmmmm.
Offline Kelly E
  • Geriatric Hooligan
« Reply #40 on: September 22, 2020, 06:18:40 PM »
I have seen more than a few engine rebuilds fail because something was missed during the cleaning process. The guy who taught me said to do four complete cleanings, each one as complete as you think the first one was before you start the build. 8)
Don't quit now, you have come so far. Listen to Bryanj, take it apart. It will be much easier for you to put it together the second time. Clean it out like you just started the build after you find what failed.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline jakec
« Reply #41 on: September 22, 2020, 06:39:59 PM »
Ok here is what I found so far.
No broken rings. No blowby. Some vertical scoring in sleeves. One white colored valve #3 intake. Inside of engine smells like pork rinds.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline minimo
« Reply #42 on: September 22, 2020, 06:44:22 PM »
Well, that’s some semi-good news.
To me, those cross hatches look pretty heavy.
How’s your cam chain and related parts and areas around it?
« Reply #43 on: September 22, 2020, 06:47:08 PM »
That is a pretty good scuff looks like .. not end of the world.. but its sorta low hours I think.. ?
 Inner cylinder ?
 Did you pull out the pump rotor ? I wonder if it maybe sheared the key  from debris..,  if it turning now with shaft  it could still be broken.. and start slipping under pressure..
« Last Edit: September 22, 2020, 06:49:50 PM by 754 »
Offline jakec
« Reply #44 on: September 22, 2020, 06:47:20 PM »
Can shaft looked great, chain great, nothing looked out of the ordinary. I did test the metal flakes and they seemed non magnetic
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline jakec
« Reply #45 on: September 22, 2020, 07:10:16 PM »
Yes you can see that the key did damage both the shaft and the rotor
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline jakec
« Reply #46 on: September 22, 2020, 07:12:39 PM »
What I’m wondering is, if the vapor blasting medium caused this, wouldn’t it be most evident at the first oil change? Because that oil was great (no debris). This strikes me as more of a sudden failure, bust based on the size of the flakes.
The threads I read about vapor blasting is that it scores up your crank and bearings, or even causes it to seize. But these flakes seem to be aluminum so it would be from either of those parts
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #47 on: September 22, 2020, 07:22:37 PM »
What grit was your cylinder hone? Did you do the hone work or did a shop do it?
Offline jakec
« Reply #48 on: September 22, 2020, 09:37:12 PM »
I had it professionally done at a place here in Seattle recommended by a few members here. Don’t know what grit but I gave them the instructions mark gave me to pass on. Related to decking.
http://forums.sohc4.net/index.php/topic,179579.75.html
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline Nurse Julie
« Reply #49 on: September 23, 2020, 04:59:14 AM »
Difficult to tell from a photo but have you got some bits missing from the oil control rings or are those the ends?
« Last Edit: September 23, 2020, 05:00:51 AM by Nurse Julie »
