Author Topic: Mystery CB750K Part  (Read 1107 times)
Offline Maltboy
  • Pitter-patter, let's git at 'er!
  • Making stupid mistakes since 1959
Mystery CB750K Part
« on: September 26, 2020, 04:03:17 PM »
I found this spring lurking in my CB750K5 parts bin today. I keep everything in labeled Ziploc bags just to prevent stuff like this from happening, but it happened anyway. Does anybody have any idea what this thing is? It measures 21 mm tall and 28 mm in diameter.
Offline BenelliSEI
  • 1969 cb750
Re: Mystery CB750K Part
« Reply #1 on: September 26, 2020, 04:43:43 PM »
That spring goes under the oil filter, before you slide it down over the retaining bolt (in the housing). If you look at a parts drawing, you will also see a washer that goes between the filter and spring. It’s almost always missing. It sticks in oil, to the  filter end and usually gets tossed in the garbage...,,..
« Reply #2 on: September 26, 2020, 05:12:57 PM »
Yes it is  and yes washer should be there.
Offline Maltboy
« Reply #3 on: September 27, 2020, 04:34:42 AM »
Thanks! I'm not sure how it got left out of the other oil filter parts.
