Author Topic: Side hard cases for CB750  (Read 1003 times)
« on: October 03, 2020, 03:42:18 PM »
Is there a luggage solution for CB750 that does not require alternating rear turn signals?
Offline MJL
  • Don't listen to me, I'm no
Re: Side hard cases for CB750
« Reply #1 on: October 04, 2020, 02:21:02 PM »
I have some vintage Shoei hard bags that replace the rear turn signals
Offline Bankerdanny
  • Endeavor to persevere
« Reply #2 on: October 04, 2020, 02:22:50 PM »
Given how far the stock signals sick out, I don't think so. Fortunately they aren't hard to remove
« Reply #3 on: October 04, 2020, 03:25:14 PM »
I considered Shoei hard bags for Red, got them from MoMo in Gap and sent them South to some member in Carolinas???
I was looking at Apache hard cases at Harbor Freight:
https://www.harborfreight.com/4800-weatherproof-protective-case-x-large-black-64250.html
they feel very solid and are waterproof, too.
But for my upcoming trip, Tour De Children  ;D I bought Rock Bros soft bags on Amazon, they should come on Tuesday.  They got good reviews.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #4 on: October 04, 2020, 04:23:05 PM »
I used Pelican cases comparable to the Harbor Freight Apache cases:
I set the bags far enough to the rear to retain passenger footpeg functionality. I also designed the primary support bracket to accommodate relocating the stock signals further back requiring only a removable (plugable) extension for the wire leads.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #5 on: October 05, 2020, 02:01:22 AM »
Thank you, Wilbur.
Do you have picture of the frame under those cases?  Also how do you attach them?
« Reply #6 on: October 05, 2020, 05:11:08 AM »
Thank you, Wilbur.
I am really happy with the way they turned out. I figured I would have to do a write up (with pictures!) of the mounting brackets, so I'll try to do that soon. There are only three pieces that form the supports for the side bags. There are two more crossover brackets to support the trunk. The main supports are stupid simple, just a piece of 1-1/4"x1-1/4"x1/8" (maybe 1-1/2", I'll have to check) angle on each side. This is attached at the upper shock mount and the rear fender bolt. I was not able to use the stock grab rail but did have to use a spacer to align this mounting point with the upper shock mount. Another 1"x1"x1/16" (or 1/8") tubing for a crossover torsional brace between these two pieces of angle above the rear fender just in front of the taillight. A piece of the 1"x1" square tube was welded to the underside of each angle, near the rear, to provide a third mounting point for the case and to stabilize the lower part of the case. A simple bracket to lock the case to the bike that uses the padlock on the case latch. Remove the lock, lift the bracket, and the cases lift off, no tools required to secure or remove the bags.
EZPZ  8)
It took me at least two weeks to figure out the design and only an afternoon to fab it up.
TAMTF...
Wilbur
Projects:
Offline Bankerdanny
« Reply #7 on: October 05, 2020, 07:41:14 AM »
It looks to me like all of the option so far still require removal of the stock turn signals.
« Reply #8 on: October 05, 2020, 08:12:35 AM »
All I had to do was relocate further rearward, using the original stock signals. Removing the brackets permits putting them back in their original location, no modifications, just temporary relocation while the bag brackets are installed.
TAMTF...
Wilbur
Projects:
