Author Topic: 18 inch rear wheel size for a cafe racer  (Read 973 times)
Offline crxnug
« on: October 04, 2020, 05:01:11 PM »
I have a 1978 cb750k that im in the process of turning into a cafe racer, i want to change the rear wheel to a 18 inch  , im going to buy a new rim and just lace in my 78 hub assembly can anyone recommend the width of rim that will be best suited or if someone has some recommendations, any help would be much appreciated
Offline low-side
Re: 18 inch rear wheel size for a cafe racer
« Reply #1 on: October 04, 2020, 05:37:09 PM »
Really depends on what width tire you want to run.  You'll want a 3.00" wide rim for a 130 or 140 wide tire.  If you want an old school look with a narrower tire a 2.15 will work.
« Reply #2 on: October 04, 2020, 07:38:57 PM »
What do you have on the front.. for starters  ?
Offline crxnug
« Reply #3 on: October 05, 2020, 03:13:24 AM »
I have 19 on the front currently
Offline Alan F.
« Reply #4 on: October 05, 2020, 09:59:47 PM »
I think he meant what width front are you planning?
Offline crxnug
« Reply #5 on: October 08, 2020, 04:11:01 PM »
i have a 19  1.85  up front, what size tire would i use if i were to go with a 2.15 on the rear,
Offline Bankerdanny
  • Endeavor to persevere
« Reply #6 on: October 08, 2020, 07:56:37 PM »
I think 100/90  is optimal,  don't go wider than 110. A wide front tire doesn't improve handling.
Offline low-side
« Reply #7 on: October 10, 2020, 05:30:16 AM »
I have that same mix of sizes with my Lester's.  I'm running 90/90X19 front and 110/90X18 on the rear.
