New to the forum and have been lurking for a while now. I have a '74 CB750 in the Flake Sunrise Orange. My dad originally bought it brand new in '74 and has kept it in a garage ever since. In 2000 I started riding it and it only had about 3,000 miles on it. I rode it for a few years and it went back into the garage until this summer. It has about 6,200 miles now. Had a few things replaced to get it road worthy... rear shoes, front pads and a new caliper since the old one was seized up, new brake hoses and new master cylinder and brake lever assembly since nothing would pump through the old hoses, new rear shocks, oil/filter, air filter, new plugs. Starts right up and runs like a champ.
I have an oil leak in oil hose B which I believe is the return from the engine to the oil tank. It's dripping after a ride and the bike and oil is nice and hot. Drips from the ferrule on the hose where it meets the braided line down near where it connects to the engine. I assume the line in there is cracked and with the heat the thin hot oil is leaking out. After it cools, the next day it stops dripping. Read a ton of posts about having a shop make a new hose using my connectors and I found one that will do it so that's not an issue.
Question is, since it's the return line, can I remove that hose without draining the oil from the tank? The tube in the oil tank for the return should extend above the oil level in the tank, right? The feed hose behind it looks fine, no leaks. I just changed the oil so I don't really want to drain it again to change this hose, but I guess if I have to it's not like I have to do a full oil change, just refill the oil tank when I'm done I guess. Any advice/suggestions?
Love all the pics of everyone's bikes.
