Author Topic: Gasket sealers and dressings  (Read 415 times)
Offline Maltboy
  • Pitter-patter, let's git at 'er!
  • Making stupid mistakes since 1959
« on: October 14, 2020, 09:26:07 AM »
I read the leak-free top end thread, and I'm wondering what are y'alls thoughts on using Permatex copper spray on a multi-layer head gasket and jug bottom gasket?
Should I use Honda Bond on the oil pan? How about the valve cover?
Offline Bodi
Re: Gasket sealers and dressings
« Reply #1 on: October 14, 2020, 11:37:02 AM »
The oil pan should just have the dry gasket - you may want to remove it to check the pickup screen or pull the oil pump, and sealant will. Valve cover should seal with its gasket/o-ring alone.
Sealing spray should be fine on the barrel and head gaskets.
Offline Maltboy
« Reply #2 on: October 14, 2020, 07:03:53 PM »
Thanks for the info!
Offline Maltboy
« Reply #4 on: October 15, 2020, 01:43:10 PM »
Thanks Dave. I'll install it dry, as I did with the jug gasket and oil pan gasket.
