Ha, thanks, Rob. I knew you were as nuts as I am. BTW, I still consider building the ultimate homebuilt fluid synchronizer. That is, when I can overcome my laziness. It is not that I need one. My 4-gauge set is in a friends workshop. But it must be rewarding to create such a thing yourself, using the cheapest parts imaginable. The challenge will be to have exactly the right damping ofcourse. In spring I'd like to see if a thin straw (the small Ø WD-40 cans have) can do the trick. It will take some experimenting. I guess one needs extra long vinyl tubes that almost reach the ceiling. For fluid I suppose red ATF will be fine.
