Author Topic: Chasing threads  (Read 3003 times)
Offline The Gurg
Chasing threads
« on: November 04, 2020, 05:43:12 PM »
10mm x 1.25 bolts for the shock mounts on a cb750 K5. Acorn nuts aren’t threading on. There is a bump on the third thread. This will be my first time chasing threads. With the engine mounted, chasing thread on the frame makes me a little nervous. Looking for any tips. Planning on picking up a hex die tomorrow. Going to use bel ray to lube the die unless someone objects.
Online HondaMan
Re: Chasing threads
« Reply #1 on: November 04, 2020, 05:52:29 PM »
Do you have some needle files? A small triangular file should be able to smooth the edges of that bump down to let the nut thread back on.
Re: Chasing threads
« Reply #2 on: November 04, 2020, 09:23:40 PM »
Yeah what Hondaman said.  Triangular is the right profile, if you have a very small  file with a oval cross section, use it first to remove a lot of it. Probably won't need a die , but don't force the nut.. and a few drops of oil is good.
Offline pjlogue
Re: Chasing threads
« Reply #3 on: November 05, 2020, 02:13:50 AM »
If you do use a die, be sure the thread pitch match the stud.  I seem to recall the thread pitch being hard to find when I was restoring my '76 750 and finding the nuts was difficult.  Hand start the die as they are easily cross threaded because of the taper on the die.  Use oil as well.
-P.
Offline jlh3rd
  • "just who gets to determine my needs?
Re: Chasing threads
« Reply #4 on: November 05, 2020, 03:32:16 AM »
i use this tool called threadmate. It works on any pitch thread.....Its about 1/2 inch thick so a male stud needs to be long enough. Its saved many bolts.
"alleged greed is usually a lazy person's opinion"
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Chasing threads
« Reply #5 on: November 05, 2020, 03:55:23 AM »
I prefer something like this when repairing threads:
https://www.amazon.com/Lang-972-Fractional-Metric-Restorer/dp/B000P6UNHE
These are less aggressive than actual taps and dies and can even push damaged threads back into shape (especially threads in aluminum) instead of cutting everything out of the way. The thread files are nice too but they do require a little practice, patience, and a steady hand doesn't hurt either. I got so much use out of my 40 piece set I bought another set with 48 pieces. You may need to address the threads inside the acorn nut as well.
Ye-ow! That is a little steeper than I imagined:
https://www.amazon.com/NES-Thread-Repair-NES01044-ThreadMate/dp/B003YIB38I
although I'm not afraid to spend money on tools...  ;)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline jlh3rd
Re: Chasing threads
« Reply #6 on: November 05, 2020, 04:17:16 AM »
no,no...that's not it....look at the pic....i bought that little tool years ago. Actually, purchased from Griots garage but i'm assuming it's out there in general.........
Offline jlh3rd
Re: Chasing threads
« Reply #7 on: November 05, 2020, 04:24:50 AM »
here's something similar.......still kinda expensive......but, has saved me countless times....
Re: Chasing threads
« Reply #8 on: November 05, 2020, 05:04:01 AM »
I believe it is. The tool I linked to has both tools, one for the external thread (like yours) and also the tool for repairing internal threads.  8)
TAMTF...
Wilbur
Projects:
Offline jlh3rd
Re: Chasing threads
« Reply #9 on: November 05, 2020, 05:21:11 AM »
no, here is exactly what i purchased years ago....just this single tool.....no internal.
Re: Chasing threads
« Reply #10 on: November 05, 2020, 05:31:54 AM »
Another option is a thread chaser file. Most are  four sided, and each end is different. They come in metric and standard pitches, so each file has 8 different thread sizes. Just lay the correct one in the threads and use a rolling motion as you file......  I’ll add a photo. Next time I am in the shop. Saved many a bolt and stud with my set!
Just added “Amazon Photo”. Note the metric file at the bottom (like the one I use) has 8 different cutting faces (4 at each end). So one tool is all you need for your metric bike. Lifesaver.
« Last Edit: November 05, 2020, 06:00:53 AM by BenelliSEI »
Offline jlh3rd
Re: Chasing threads
« Reply #11 on: November 05, 2020, 05:47:21 AM »
since you say this is your first time, the problem i'd have recommending a die is that if you don't get the die started correctly, which might prove difficult for a first timer, and because the threads are screwed up at the tip......you might start cutting threads crooked....because that's what a die is for...cutting threads.
     Tools that let you line it up with the undamaged threads as a guide, will enable you to correctly repair the damaged threads.....that's what benelli's tool will do, the one i use also.........triangle files i've used also , but space may limit access.........
     yes, a die can work.........i've done it........but i've been doing this stuff for decades..........i really like that  tool i have but it only goes to 1/2 inch......
Re: Chasing threads
« Reply #12 on: November 05, 2020, 10:25:53 AM »
What madmtnmotors has are actual "thread chasers",they remove the least amount of metal while actually restoring the existing threads.A regular die or tap will cut more metal off and cause the threads to be more loose w/ more of a chance of stripping-out the threads later.. Buy a set of "thread chasers" rather than a tap or die.I especially like running the 6mm male chaser down into cast aluminum threads,makes a very smooth threaded hole with those small ones w/o reaming-out the original factory threads like a 6mm regular tap used to do.,cleans-out build-up too.
I purchased these for small $ from a place in Ma. called metricscrewandtool.com,I bought these from them on Ebay but they also have a site you can purchase Many metric bolts,nuts,screws and tools.
« Last Edit: November 05, 2020, 08:43:01 PM by grcamna2 »
Offline The Gurg
Re: Chasing threads
« Reply #13 on: November 05, 2020, 12:12:15 PM »
Bought a thread chaser file. Seeing that BennelliSEI suggested it. Going to give that a try when I get it on Monday. Everyone mentions a small triangle file. Is this file small enough? Should I give it a try first?
Was watching a video about using the hex die nut and does seem a little challenging to get it started if the issue is at the start of the threads. So I’m going to hold off with that for now like jih3rd suggests.
Re: Chasing threads
« Reply #14 on: November 05, 2020, 12:22:47 PM »
Needle file set of 5-6 different shapes is useful.
Tringular shape and other to repair threads.
A flat one when gapping piston rings. File fastened in a vise, clamp ring ends around file and move inwards.
Offline jlh3rd
Re: Chasing threads
« Reply #15 on: November 05, 2020, 12:59:00 PM »
your trying to repair a threaded, non removable part of your bike. If you screw it up, it becomes harder to fix, perhaps not fixable. I don't think it's replaceable, right?
     So that thread chaser you have is not what benelli showed you. It's different. Actually, i don't see how yours would work. Look at his pic, that tool has specific, matched threads to fit into the good threads, line it up correctly, and dress the damaged threads.
Also, yeah, i guess your file would work, but look at your edge compared to mine (pic). Mine is sharper and lets me get into the groove without grinding away at the sides. Yours looks pretty worn.....but i'm not there to really see...
Just offering opinion, as you've asked.....i'm treating it like it's my bike though...
Re: Chasing threads
« Reply #16 on: November 05, 2020, 01:01:13 PM »
The needle file set is a good idea also:the smaller the file,the better.
Offline The Gurg
Re: Chasing threads
« Reply #17 on: November 05, 2020, 01:39:45 PM »
The picture of the file is just the one I have on hand. Sounds like I shouldn’t use it. This is the one that is coming Monday:
https://www.fastenal.com/products/details/0817944
Several suggestions to get a needle file set. Going to pick one up to have around. Surprised at how cheap a lot of these are. Harbor Freight has a set for $3. Anyone have any recommendations.
Offline The Gurg
Re: Chasing threads
« Reply #18 on: November 05, 2020, 01:48:52 PM »
Would get a buckingham thread chaser or thread mate or something similar. Seems a bit pricey for this repair, but maybe not? I could definitely be talked into it.
Offline jlh3rd
Re: Chasing threads
« Reply #19 on: November 05, 2020, 01:50:07 PM »
your good then....needle files, great......harbor freight?...that's a toss up. I've had good/bad experiences. I've stayed away from their wrenches, sockets...pry bars have bent fairly easy....that kind of stuff......files? eh, probably work for ya a few times, and be ok in this case....i have a list....let others chime in....
hard to go wrong for $3...can't screw anything up..
« Last Edit: November 05, 2020, 01:51:42 PM by jlh3rd »
Offline jlh3rd
Re: Chasing threads
« Reply #20 on: November 05, 2020, 01:52:29 PM »
well,  $34 bucks....
Offline The Gurg
Re: Chasing threads
« Reply #21 on: November 05, 2020, 02:00:41 PM »
Oh, it is only $34! Says metric and 10mm is in the range so that looks right. I went ahead and bought it. Arrives Sunday.
So now the question is which tool to use first...
I’ll probably practice on some old rusty 10mmx1.25 bolts. Mash the threads with some channel locks or a hammer.
« Last Edit: November 05, 2020, 02:12:07 PM by The Gurg »
Re: Chasing threads
« Reply #22 on: November 05, 2020, 02:10:31 PM »
WAIT for the one from FASTENAL. That seems a hell of a price, but I bought my pair 40 years ago.....
One is metric, one’s imperial. As I explained earlier, with the 8 X filing faces, you get 8 different pitches on one file..... it has the advantage that you can repair any bolt or stud size, and do it in place. It will last you forever.
Offline Prospect
Re: Chasing threads
« Reply #23 on: November 05, 2020, 02:18:36 PM »
This is what I use. It's essential for dealing with our old steeds.  Used it today on several threads.  It gives a euphoric sense of satisfaction when a bolt goes in like new.
« Last Edit: November 05, 2020, 02:20:19 PM by Prospect »
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Re: Chasing threads
« Reply #24 on: November 05, 2020, 04:51:03 PM »
I have used small files with good results. Take your time, do a little at a time, and check frequently. I would suggest a different nut of the same size/pitch as the acorn nut unless you have been able to verify that the threads in the acorn nut are not similarly damaged. The same suggestion applies to the use of an actual thread file as well.
TAMTF...
Wilbur
Projects:
