Author Topic: Top End Oil Leak  (Read 801 times)
Offline PhillyCheese123
Top End Oil Leak
« on: November 08, 2020, 05:44:28 PM »
Hi everyone
Recently picked up a 73 cb750 engine. Previous owner said that when he parked the bike, the engine had been leaking oil pretty badly. He said that the leak is in the top case and he suspects a failed "rubber seal". I'm somewhat of a newbie to wrenching and motorcycles in general. Not quite sure what he meant. Any ideas?
Already started taking the top case apart so I'm wondering what I should be looking for.
Re: Top End Oil Leak
« Reply #1 on: November 09, 2020, 01:26:35 AM »
There are rubber "pucks" between cam towers and head plus seals at head gasket and base gasket.
Also the studs/bolts holding the cam towers can leak down the threads
« Reply #2 on: November 09, 2020, 05:41:37 PM »
Bryan has one of the sources right: another can be leaks from the cam bearing studs, especially if someone took them out and didn't seal them when reinstalling.
Also:
if someone before you replaced the head gasket, they very likely introduced the oil leak by not installing thicker O-rings at the 2 oil ports at the back of the cam chain tunnel, on top of the cylinders. VERY common. You can also mill off the cylinder deck instead: I recommend both, and do that with all these engines I rebuild. This leak can be determined by WHERE the oil is coming from: if it is coming out of the front of the cylinders just below the exhaust ports, this is the culprit.
Also possible (but rare, have only seen it 3 or 4 times) the cam cover gasket may leak. This can be caused by a dozen things, including a warped, damaged, or cracked cam cover gasket surface, all usually at the hand of a poor mechanic.
« Reply #3 on: November 09, 2020, 06:46:55 PM »
Thank you both for the pointers. I’ll be on the lookout for each of those possibilities. Got the cam shaft out today so if I don’t find the culprit soon I may be back with more questions!
HondaMan - your book is serving me well!
« Reply #4 on: November 21, 2020, 06:42:23 PM »
I'm glad it helps, thanks for getting one!
