Logo merchandise is available at the SOHC/4 Shop
Yes, you camSent from my iPhone using Tapatalk
Usually ground... look for a place that does it often and is set up for it Godfrey , I think is one of them..
Quote from: 754 on November 21, 2020, 06:33:16 AMUsually ground... look for a place that does it often and is set up for it Godfrey , I think is one of them..When you say grind how different of a process is that than turning and cutting on say one for a car disk? Sent from my moto g(7) using Tapatalk
Evinrude , you were sooo close to the finish line with your wheels.... If you just want to spiff up the rotors spin them in a late and block sand it.. amazing.. but you have to cover the lathe ways and clean chuck real well..
Several alternatives...blue loctite, nyloc nuts, safety wire or buy new "nut savers" from honda
That “sprocket cover” always fascinated me. I suspect it’s purpose is the ensure a broken chain doesn’t get down and tangle on the axle? Anyone know?PS. Toss it.
