There are some guys from Sweden here
You can get the clip to fit, right?
Those look like Cruzinimage pistons. No hot cam with those.
There is a long forum thread about them.
I usually fit the clip on one side before assembly. Push the wrist pin from easiest side to fit the last clip.
Fit the clip you have doubts about and test with wristpin, push it and see that clip will sit.
If wristpin has a tight fit heat the piston with a heatgun, oil the holes.
Honda stock clips do not have the G shape, more like an O and look like to sit better.
At my last piston replacement I used the Cruzinimage clips.
