Author Topic: Steering Damper for CB750K1  (Read 991 times)
Offline pjandrew99
« on: November 19, 2020, 07:19:12 AM »
From what I can gather on the threads, the most recommended dampers were NHK Z900 or ODM 2000. Any advantages of one over the other. Would a different one be better for the CB750K1?
Also, is it better to mount cross frame or the same side?
Thanks!
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
Re: Steering Damper for CB750K1
« Reply #1 on: November 19, 2020, 08:47:01 AM »
This work fine on a street bike.
Both my bikes have one. My K6 has this very kit, my K2 same parts from the 80's.
https://www.yamiya750.com/index.php?main_page=product_info&cPath=246_145&products_id=231
Offline pjandrew99
« Reply #2 on: November 19, 2020, 02:35:05 PM »
Thanks!
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
Offline Doobie
« Reply #3 on: November 20, 2020, 08:36:17 AM »
I've used the NHK ODM-500 on three CB750s. Sells for $90-ish. The length is correct and it mounts on the right side. Here is a mounting bracket I use:
« Last Edit: November 20, 2020, 08:51:06 AM by Doobie »
You only go around once in life so it might as well be on a motorcycle.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
« Reply #4 on: November 20, 2020, 11:50:18 PM »
Mounting bracket is important.
I used an exhaust clamp in the 80's that made a flexy assembly, not good as a real bracket as sold with the CB750 kits.
I was too cheap saving a few bucks.
Steering damper really useful when rear tire is worn and cause rear  wobble.
Or when having luggage and passenger making the front end very light and front wobble occur.
