Author Topic: K2 front tire  (Read 722 times)
Offline beemerbum
K2 front tire
« on: November 22, 2020, 11:16:52 am »
Wanting a vintage look, I have installed a Dunlop K81 4.25-18 on the rear. The recommended tire size for the front is 3.25-19. It seems the only front wheel Dunlop K81 available is a 4.10-19. Will this fit the 1972 CB 750 front wheel without interfering with fender etc? A K70 in 3.25-19 is available. Would the dissimilar tread patterns look offensive to the purist? This bike will never be ridden at the recommended maximum speeds of these tires.
Re: K2 front tire
« Reply #2 on: November 22, 2020, 01:21:32 pm »
Yes it will fit perfectly, its the metric equivalent of the 3.25x19
Re: K2 front tire
« Reply #3 on: November 22, 2020, 07:35:57 pm »
Intersting numbers on the modern version of the K81 tires...
The original rear tire (4.00x18) in K81 trigonometric size was 5.10x18. It was 1/8" taller than the 4.00x18 when mounted.
The replacement front for the 3.25 to 3.50 x 19 front was 4.25x18. It sits as high as the 3.50x19 tire when installed.
