Author Topic: Carb Bowl Drain Plug WASHER?  (Read 924 times)
Offline jakec
« on: November 26, 2020, 06:27:15 PM »
Is there meant to be a washer on the drain plug on round top carbs?
I have #2 carb leaking from the drain plug and I was going to shop for new O rings, and CMSNL says that there is also a washer in the fiche. I haven't seen this for any other hondas?
Sidenote, does anyone know the O ring size for the drain screw on round top carbs?
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Re: Carb Bowl Drain Plug WASHER?
« Reply #1 on: November 26, 2020, 06:56:52 PM »
The O-ring for those with the big-head brass screw is 1.6x4.7 or 1.6x4.8mm.
The early carbs from the K0 bikes had a separate, soft aluminum washer instead, and they have a smaller head (and are silver colored, not brass). The end of the K0 carbs had this same screw-washer, but in brass. There's not many of those out there.
Offline jakec
« Reply #2 on: November 26, 2020, 07:10:50 PM »
My round top carbs are off of a 1972 so a K2? Their fiche shows washers.. actually it shoes two items as #52, one washer and one O ring. I guess O ring is correct. (#52 bottom right)
Thank you for the O ring dimensions.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #3 on: November 26, 2020, 07:12:16 PM »
Jakec...... vintage CB750.com sells the screws, for all years, complete with “0” rings. Or, the rings can be purchased separately.
« Reply #4 on: November 26, 2020, 07:46:11 PM »
be aware that float bowls, and even entire carb racks got switched ALOT over the years...so be sure you know what you have...I think k1/7a use a different size drain screw and o-ring(smaller) than later years (larger)
« Reply #5 on: November 26, 2020, 09:07:57 PM »
 If I remember correctly I have a bag of 7/32 o-rings I use for the drain screws on 550's and 750's.
Offline jakec
« Reply #6 on: November 27, 2020, 10:41:59 AM »
I placed me order at the O ring store per the sizes that Mark gave. The O ring store is great.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #7 on: November 27, 2020, 02:44:08 PM »
 I ran across the 7/32 size while doing some 500 and 550's awhile back using this faq.Sizes listed worked good for jets etc. if anybody runs across this and been using the 7/32 on drain plugs since on my 750's. Reply #9 - http://forums.sohc4.net/index.php/topic,5410.0.html  Luckily not much rubber in round top carbs and they are pleasant to work on compared to some others  ;)
« Last Edit: November 27, 2020, 02:45:54 PM by ekpent »
Offline jakec
« Reply #8 on: November 27, 2020, 08:08:53 PM »
I shuffled my drain plugs around today and the same carb was leaking. Definitely through the plug, not the drain, it is fairly obvious after watching it. I'm wondering, once I get the new O rings, if it isn't fixed, is it ok to use a dab of gasket sealer on the threads? Anyone done that before?
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #9 on: November 28, 2020, 06:47:47 PM »
It will likely dissolve and end up stuck in the jets. I don't think it would be a good plan?
« Reply #10 on: November 28, 2020, 07:01:21 PM »
Is your overflow tube cracked ?
Offline jakec
« Reply #11 on: November 29, 2020, 11:03:25 AM »
It’s not coming out of the overflow tube, it’s coming out of the screw.. the screw is way above the overflow tube and gas if forming droplets on the screw. I think I have gas resistant sealer, I was thinking about putting a tiny dab on the O ring? Maybe? But first i’ll Just check with new O rings to see if that fixes it.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #12 on: November 29, 2020, 12:11:26 PM »
I would look closely at the threads into which the drain plug screws. If those have been screwed up (no pun intended), you'll get leaks... even with a new oring.
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
« Reply #13 on: November 29, 2020, 12:39:08 PM »
If it's the screw, how about some PTFE (plumbers) tape around the threads? It's both petrol and oil resistant and I have used it on my brake calliper bleed crew to good effect.
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
« Reply #14 on: November 29, 2020, 05:05:59 PM »
 You could goop up the threads if a new o-ring doesn't work with a product called Seal-All but I doubt you would ever get it out again. Great stuff. I have used it inside carbs and other fuel related places and even fixed the sole and glued it back together on my work boots. Its a miracle goop I tell ya ! ;D ;D
  Wonder if the bowl has a tiny crack somewhere around that screw housing.
« Last Edit: November 29, 2020, 05:12:15 PM by ekpent »
Offline jakec
« Reply #15 on: November 29, 2020, 11:19:47 PM »
I have yellow plumbers tape (for petcock) that seal-all product as well (but not sure if it's gas-resistant)? Seems I have 3 options!
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #16 on: November 30, 2020, 05:26:00 PM »
I have seen these bowls with a cracked or corroded drain tube that weeped fuel out the bottom: it creeps along the bowl to the bottom of the srew, then drips.
To  see if yours is doing this, apply some sealnat around the outside of the drain tube and see if it stops. Another bowl is the cure: there are "left" and "right" bowls.
Offline jakec
« Reply #17 on: November 30, 2020, 06:20:29 PM »
It is a #2. Hm might be a tough part to find... I once fixed a leaky drain tube by soldering.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
