Hey guys, I'm finishing up a CB650 build and am having a hell of a time figuring out this last big issue. The bike doesn't seem to always be running on 4 cylinders, or at least not completely; the header on cylinder 3 is always about half the temp of the headers on cylinders 1,2 and 4. (Cylinder 3 is around 150 degrees when the others are 300+).
I'm pretty sure it's not electrical, I've swapped plugs, caps, wires and even switched the coils between sides, and cylinder 3 is always half the temp. The plug in the number 3 cylinder is a bit wet though so it looks like it's getting fuel (maybe too much? maybe too little?) I'm running brand new Keihin CR29 carbs, so I doubt (but haven't completely ruled out) it being a carb issue.
I did a compression test and all 4 cylinders were about 140 so that would point to the carbs but not sure why or where to start.
Any thoughts or suggestions would be greatly appreciated.
