Author Topic: 90 degree m10 banjo brake hose  (Read 674 times)
Offline wolf550
« on: December 07, 2020, 06:14:23 PM »
so i finished the rear break master cylinder reservoir adapter to fit on the rearset but now I need a brake like that bends 90 degrees to the M//C thats 18 to 20 inches. any shorter I dont think there would be enough slack and any longer It would be too much but if its an inch or two longer I can manage.
the only thing I could find was the 90 degree m10 fitting that connect to the 3AN fitted brake hose.
74' CB550 (Sold)
71' CB500/550 (Sold)
Re: 90 degree m10 banjo brake hose
« Reply #1 on: December 07, 2020, 08:20:18 PM »
Just order the  pieces and make a line. You can put this in, then a 90 degree end on your hose
Offline wolf550
« Reply #2 on: December 07, 2020, 08:39:05 PM »
thanks frank wasn't sure if that would be easier to do or if there was an all in one hose out there.
I'll go ahead and get the pieces ordered.
74' CB550 (Sold)
