I'm not much of a car guy. I like classic cars but have my hands full trying to keep my fleet of bikes running well. I'm thinking of buying a used full size pick up truck. I'll probably only drive it around 3000-5000 miles a year. I don't drive much. Considering how little I drive I'm thinking of getting a high mileage pick-up, maybe 10 years old, but I'm concerned about reliability. These modern trucks are difficult to work on and I'd have to take it in to the shop which is always expensive where I live (most of the shops have been bought our by condo developers and have left the city). I had a Nissan pick up in college and loved it.
What should I look for? Chevy Ford GM? I like the look of the F150 and I believe it's the most popular vehicle in Canada. Are there years to avoid? Rust prone? Red flags? Only a long box can fit a cb750?
08 silverado, 62,000, 5.3 LS engine, automatic, rear wheel dr., posi, purchased new.
I've replaced front rotors ( developed shudder, as did my 02 camaro) and the fuel purge solenoid. So far,that's it, but 62,000 is really nothing. Front end A-arms, spindles are pretty rusty. Body is fine but i do maintain it. Interior is fine, but, a small split did show up already on the driver's vinyl seat side which i feel is way too early. Engine does run nice, at a stop you can hardly tell the engine is on. Tranny is fine but i've already completed drained and refilled, and will do it again this summer. i've pulled my 24' pontoon boat with no troubles. The long bed holds my 550F easily. I don't beat on the truck, and can't answer to other negatives about GM......So....
This biggest known trouble with these gm trucks reported is related to the lifters that are part of the AFM (active fuel management ) system. Supposedly, they are prone to fail. Early LS1
aluminum block engines, such as my 02 camaro have a rattle at idle called piston slap. Yes, my 02 has it. I don't think the iron block ls1's do, but some earlier trucks might.....so google's your friend....
Knowing what i know now with all the reading and research i do, Id get a toyota.....then an F150....then a chevy......
