CycleX clutch fiber plates I ordered some years ago were very sticky.
EBC and Cruzinimage in my bikes works fine.
A costly domino effect occure when tuning the engine.
But most of it must be done anyway if restore/repair a stocker.
I had no issues with stock rods frequntly enter 9000+9500 rpm.
836cc
17:48 sprockets make bike to work better too.
My K6 with 1005cc had no issues at low rpm. I changed front sprocket to 17 from 18 to make life easier for the clutch.
Bike felt better after that. My almost stock K2 has same gearing.
Gears feels to match better.
Stock sized wheels/tires. (Rear affect gearing).
836 piston kit with valve pockets supporting hotter cams cost some. JE or Wiseco.
If lucky you might find a cylinder and piston kit if asked for it in the Classifieds, Wanted or check for sale for around $400-500 US.
Not only me that has new bored cylinders with new or almost new pistons on the shelf for future use, RC 836cc, CycleX 849cc and 61.5 mm Cruzinimage K7 pistons in K1 cylinder
It was one seller on eBay that sold a batch of NOS early style cast RC 836 piston kits 2012 for $250US.
Worked fine. I'm sure many here has a kit of those. Chambers needs to be widened a little for these.
I reused my old RC 3-oil rings since the kit had the old single.
From the forged RC pistons sold in the early 80's.
Those pistons have got another cylinder with fresh bore, used cylinder bored to next step, 849cc. I found a set very cheap on ebay a few years ago.
Here when those 836 pistons enter 10.000 rpm
