If you haven't changed the plugs ever, change them. Sent from my moto g(7) using Tapatalk
Spark plugs are cheap. Why wait for problems? Change mine at least once a year. They don't last forever. Sent from my moto g(7) using Tapatalk
Quote from: evinrude7 on December 22, 2020, 06:56:40 PMSpark plugs are cheap. Why wait for problems? Change mine at least once a year. They don't last forever. Sent from my moto g(7) using TapatalkI guess I'm a "don't fix it if it ain't broke" kinda guy and they seem pretty good, as good as a new one as far as I can tell. I'm cheap, frugal.
Quote from: juntjoo on December 22, 2020, 07:10:10 PMQuote from: evinrude7 on December 22, 2020, 06:56:40 PMSpark plugs are cheap. Why wait for problems? Change mine at least once a year. They don't last forever. Sent from my moto g(7) using TapatalkI guess I'm a "don't fix it if it ain't broke" kinda guy and they seem pretty good, as good as a new one as far as I can tell. I'm cheap, frugal. OK SURE.. you know it all better than us..... sorry for wasting your time.. Good luck next time...
Quote from: juntjoo on December 22, 2020, 07:25:44 PMBut I really do appreciate all your feedback and will humbly let you know when learn mess up not following a particular suggestionPlease correct your wording so we can read your intended meaning. Then I'll remove this reply.Thanks.There have been a number of relatively new members this year who've solicited advice for one problem or another. Much of the sound advice that was given was met with reasons why-not.... so yes, Lil touchy.
As I mentioned in my other thread I'm all fixed up. New battery did the trick! I'll hold onto these new plugs for next time. Thanks for all the help. Does a good battery help with starting? Strangely it has started tonight flawlessly several times out riding around whereas with my old battery earlier in my garage even when I'd freshly charged it it wasn't starting most of the time. Maybe after sitting it just needed to run for a bit to loosen some crud out or something?
Quote from: juntjoo on December 22, 2020, 06:30:14 PMAs I mentioned in my other thread I'm all fixed up. New battery did the trick! I'll hold onto these new plugs for next time. Thanks for all the help. Does a good battery help with starting? Strangely it has started tonight flawlessly several times out riding around whereas with my old battery earlier in my garage even when I'd freshly charged it it wasn't starting most of the time. Maybe after sitting it just needed to run for a bit to loosen some crud out or something?OH! Yes lol. My first bike I had it cranking seemingly strong, but it was a pain to start, and jumping it to my car made it start great. It might have to do with voltage drop while cranking causing weak spark. Sometimes counterintuitive.
