Author Topic: left hand turn signals having troubles identifying wires  (Read 637 times)
Offline BobberNation
  • working on a 76 CB550 Hardtail
« on: December 22, 2020, 06:43:13 PM »
i am trying to get rid of my stock levers and switches. that being said while working on my handle bars i found a brown and blue wire and a brown and white wire, brown and blue should be the signal buzzer right?? but what is the brown and white?
my other question is would a switch like this brass one work for the turn signals
thanks ya'll
« Last Edit: December 22, 2020, 07:03:07 PM by BobberNation »
Re: left hand turn signals having troubles identifying wires
« Reply #1 on: December 22, 2020, 07:33:48 PM »
Brown white is instrument lights
« Reply #2 on: December 23, 2020, 09:45:19 AM »
so im not running a speedometer could i just cut those two wires out completly??
Offline drumstyx
« Reply #3 on: December 23, 2020, 10:02:41 AM »
Brown and white is instrument lighting, but I believe it also powers your front running lights (L and R filament 1) through the switch. It's a complicated switch because it turns the running light off while also turning on the flashing second filament. In theory, especially if you go with LED lighting (do avoid overloading the circuit), you could get away with wiring the running lights straight to instrument power. It'll make the flasher less noticeable on the front though.
Best solution if you want to pare down the switch to something basic would be to wire up relays somehow to give you the same functionality as the original switch. Cheap and easy way would be to just not have running lights on the front, but then there's probably some legality issues in some jurisdictions.
