Author Topic: Looking for 9mm x 1.25 bolts,anybody know where I can get them ?  (Read 1808 times)
Re: Looking for 9mm x 1.25 bolts,anybody know where I can get them ?
« Reply #25 on: December 28, 2020, 02:00:48 PM »
Measure the stripped hole, see if it's still ok for 9mm... if not 3/8 20 is yer ace in the hole..m
« Reply #26 on: December 28, 2020, 03:03:15 PM »
Ok so just to help here, see if you can get a member to make  some bolts out of hex , or studs out of rod..
 They only got to know the length , and even if they cut only 85 % -of thread , you die will finish it easily.
 You just need to tell them length and maybe send material.    9/16 hex ought do it.
 You any want to  safety wire them..
I would like to purchase 6) Grade 8 steel 10mm allen head bolts 25mm long and have them turned-down to a dia. of .360" which is the O.D.of the outside measurement of the threads of my never used 9x1.25 tap;I also have a new 9x1.25 Die.The allen head will fit between the footpeg good;a hex head bigger than a 12mm hex wrench will not:I have a few of these engines to install in this bike.I will send the tap and die along with the bolts.
 I will pay for this service if someone here has a lathe and the time to do this.
« Last Edit: December 28, 2020, 03:29:46 PM by grcamna2 »
« Reply #27 on: December 28, 2020, 03:09:31 PM »
Frank,the stripped threads are still holding a bit,they aren't totally stripped but the one hole is weak.The other 3) 8x1.25 bolts are holding strong.These footpegs will be removed and re-installed many times and I want to have these bolts ready for when they do ultimately strip/fail.I'm thinking/planning ahead on this job,glad I did as the problem sourcing the 9x1.25's. I need to torque these lower bolts to around 17-18 ft/lbs plus keep the threaded holes in the crankcase clean(very difficult with chain lube,oil,etc. down there)so I get a true torque reading.
« Last Edit: December 28, 2020, 03:17:27 PM by grcamna2 »
« Reply #28 on: December 28, 2020, 04:10:47 PM »
Blanks should be around .350  before threading..  9 mm equals . 354.
« Reply #29 on: December 29, 2020, 11:12:32 AM »
Where can I find allen head bolt blanks to thread 9mm ?
« Reply #30 on: December 29, 2020, 12:56:36 PM »
Turn 10 mm orv3/8 down,  they are fairly hard, if your die is carbon steel, it may not live long. .
« Reply #31 on: December 29, 2020, 01:03:26 PM »
How about grade 5 ?
« Reply #32 on: December 29, 2020, 01:50:30 PM »
That should be softer.
« Reply #33 on: December 29, 2020, 07:51:04 PM »
Who sells them ?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #34 on: January 05, 2021, 04:24:40 AM »
https://www.factorychryslerparts.com/products/Jeep/BOLT-Hex-Flange-Head-M9X125X2600-Mounting/8657035/06509983AA.html
The "Hex-Flange-Head" description misses the mark since this uses a T-50 Torx drive. I would still be inclined to do a helicoil repair and be done with it...
« Last Edit: January 05, 2021, 06:57:52 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
