Author Topic: Kibblewhite swingarm bushings - machining?  (Read 753 times)
Offline flybackwards
« on: December 27, 2020, 07:05:42 PM »
Swingarm bushings on my K7 rebuild were completely history - looks like the shaft was not lubricated in 47 years. I have a nos shaft which will get modified per the Hondaman instructions but the Kibblewhite bronze bushings are - according to Kibblewhite - manufactured to a diameter which is smaller than the shaft so they can be honed to fit after installation in the swingarm. All seems very reasonable and exact - my question (finally) is how have others gone about honing the id of the bushings after installation? I'm not sure of what tooling or technique beyond finding a machine shop...thanks.
Offline onepieceatatime
Re: Kibblewhite swingarm bushings - machining?
« Reply #1 on: December 27, 2020, 07:16:08 PM »
With a small hone such as these, https://www.amazon.com/brake-cylinder-hone/s?k=brake+cylinder+hone chucked into a drill.
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
« Reply #2 on: December 27, 2020, 08:22:21 PM »
Buy a cheap expanding reamer ... KBC tools has them. Turn it with a tap wrench..
 You cansteer a reamed .. but you can't steer a hone..
