I put the finishing touches on the rear end of the 400F tonight and got some of the smaller things mounted.  After I got the turn signals mounted I hooked up the battery and tested the switches and lights.  Everything lit and "switched" except for the right rear turn signal.  I checked the connections for it, which were all good.  I removed the amber cover and checked the bulb, which was also good, and found that if I pushed the bulb in it would be begin to flash.  I removed the turn signal from the bike and disassembled it.  I found the black center wire has become disconnected from whatever/wherever it was soldered to.
Anyone encountered this and can tell me where I need to solder it back to?  Wire and end are intact.  The glob of solder is even still there.  Just need to know where its home is so I can get it back together and move on to the next phase.  These are the stock, and as far as I can tell, original rear turn signals.
Thanks for your help and time.
