Author Topic: Bars that clear lowered forks?  (Read 980 times)
Offline ratkiller
« on: January 05, 2021, 10:58:45 AM »
Any body know of an aftermarket handlebar that will clear lowered fork tubes?
I want to try lowering the the front end, to see how the bike handles, before I make the decision to cut the fork tubes. It would be nice to be able to continue to use the stock bar clamps with out going to clip-ons.
Re: Bars that clear lowered forks?
« Reply #1 on: January 05, 2021, 12:48:28 PM »
77 and 78  750 trees allow you to slide up as high as you want.. you then have to side tank back slightly  or mod the stops..
Offline ratkiller
« Reply #2 on: January 05, 2021, 05:32:04 PM »
Sorry, I forgot to mention this is on a 80’ cb750f super sport.
Offline robvangulik
  • Honda Fourever
« Reply #3 on: January 06, 2021, 12:18:07 PM »
That's a DOHC?
Offline Alan F.
« Reply #4 on: January 06, 2021, 01:44:08 PM »
How about some simple bolt on risers for your existing bars?
https://www.ebay.com/itm/Handlebar-Riser-Mount-Lifting-20mm-30mm-40mm-Fit-For-Aprilia-Shiver-2008-2018/183856686263?hash=item2aceb664b7:g:Os4AAOSwi7BdDR0Y
I've used this type long term for comfort, they work great.
« Reply #5 on: January 06, 2021, 03:15:13 PM »
 Handlebar set backs work too.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #6 on: January 06, 2021, 03:44:11 PM »
Why go through all the trouble of cutting the forks? They can easily be lowered without cutting anything:
http://vintage-and-classic-honda-s.456789.n3.nabble.com/How-to-shorten-forks-td4042465.html
I did this to mine without cutting the springs. Adds a bit of preload when reinstalling the fork cap, but I had no issues installing the fork cap, nor removing and replacing the spacer to make the forks even shorter on my dragbike. Easily returned to stock length.
« Last Edit: January 06, 2021, 03:46:03 PM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #7 on: January 06, 2021, 09:44:31 PM »
If you are handy with a welder make a set.5 in section on straight bar. bring up the support bars in the center. if you're not running a stock dash. if you are look into narrow window bars.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
