Author Topic: chemical engineer Q? answered is, abs sucks thanks.  (Read 1722 times)
« on: January 11, 2021, 02:59:12 PM »
 Is there anything that can be applied to dried out abs plastic to make it less brittle?  Asking because I just destroyed a K0 sidecover.  My sandcast has original covers on it.
« Last Edit: January 11, 2021, 08:31:01 PM by Don R »
Offline StockRider
  • Sustaining SOHC/4
  • Well, I thought it was stock...
Re: chemical engineer Q?
« Reply #1 on: January 11, 2021, 03:20:14 PM »
http://www.sdplastics.com/ultravioletresistance.html
"ABS is not suitable for outdoor applications because of its poor UV resistance.  Current UV stabilized grades refer only to color fastness not mechanical property retention."
https://www.rockauto.com/Newsletter/archives/62112.html#tomStory
"Boiled Plastic...", not going to help chemical breakdown of ABS by UV.
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC6981387/
"Influence of Different Stabilization Systems...."
'70 CB750K0 - "Truck" | 4x4 | 4 Cables/4 Carbs/4 Cyls/4 Pipes | PO: "Old J.O.", a.k.a. Dad, Ride Free Brother!
Offline StockRider
  • Sustaining SOHC/4
« Reply #2 on: January 11, 2021, 03:31:58 PM »
Below is a picture from the stabilization study. It cannot be related directly to virgin ABS but none-the-less, you can see the impact of UV.
« Reply #3 on: January 11, 2021, 08:20:15 PM »
 I've had two K0's that the sidecovers just crumbled off of. I'm a big fan of FB's replacements but have two originals with nice paint. Scares me to mess with them, new grommets and silicone lube.
« Reply #4 on: January 11, 2021, 08:30:13 PM »
 The moral of the story is keep them out of the sun and tanning beds. Nothing I do will help except babying them.  Skin so soft bath oil works on vinyl, I thought I might try that except for the fear that it will soak through and let the paint come off.
Offline 69cb750
Re: chemical engineer Q? answered is, abs sucks thanks.
« Reply #5 on: January 12, 2021, 07:14:07 AM »
No, abs gets brittle with age, nothing can be done.
Yamiya covers are very nice.
« Reply #6 on: January 12, 2021, 09:00:48 AM »
UK firm LPM make superb repros, its what Silver sells
Offline StockRider
  • Sustaining SOHC/4
« Reply #7 on: January 12, 2021, 10:12:01 AM »
https://www.beastauto.com/best-car-wax-for-uv-protection/
"Sunscreen" 8) and protection from extreme temperature cycles are about the only hope for old ABS parts.
Offline kerryb
  • Not a very
« Reply #8 on: January 12, 2021, 02:26:49 PM »
Does that mean I shouldn't store my abs items in the cold attic during the winter?  Temps get down to below zero F sometimes.
Conversely, sometimes the summer temps get be 115 F in the summer.
« Reply #9 on: January 12, 2021, 08:10:51 PM »
 I'm the #1 fan of FB-stuff sidecovers,  When I'm painting that's what I use. I just worry about the original Honda sandcast's sidecovers. One was NOS 12 years ago but the other one came on the bike.
« Reply #10 on: January 12, 2021, 08:14:13 PM »
Since the covers are painted, there shouldn't be a need for sunscreen UV protection. ;)
« Reply #11 on: January 12, 2021, 09:13:23 PM »
  A couple years ago I found myself on a long straight road with no intersections and a good view of empty fields on both sides of the road. I ran the old sandy up to 95 indicated, I was mostly worried about blowing a sidecover off. L0L!
Offline brewsky
« Reply #12 on: January 13, 2021, 04:48:26 AM »
I have lost 2 right sides off my '78 on the interstate......passing a semi will suck them right off!
Finally bought new grommets, so now all I have to worry about is breaking the tits off when removing them!
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
