Good evening. I drained the oil and pulled the clutch cover to have the cover vapor blasted and get the 25 year old oil replaced. Cover came out really good as did the other three items I had done. I stripped the clutch cover down for the vapor blasting - removed both oil seals and the clutch actuating arm. I have replaced both seals with new and reinstalled the actuating arm. After reinstalling the cover and filling with oil I have the following two questions:
For adjusting the clutch - the actuating arm has a stud through the center with a locking nut on the outside of the cover to lock the stud in place and hold the arm in place. Is there a certain way to set/adjust that center stud for proper operation of the clutch? Pulling the clutch lever in I can hear things moving under the cover, so I believe I am in the ballpark. I'd like to get it right and just fine tune the play with the adjustment at the lever or the outside of the case.
For the oil level - Manual says the CB400F holds 3.7 quarts. I added 3 quarts and decided to check where that falls on the dipstick since it had been 25 years since I had done an oil change on this bike. The oil level on the dipstick came to just a hair above the top line. I was expecting it to be 3/4 up to the top line since I added just 3 quarts. Will the level go down after running the bike for a short time, and then I can top it up? And where does the level normally show on the dipstick? Please keep in mind the bike has sat for 25 years, so the top end is probably bone dry and I did change the oil filter which at this point is bone dry, too. I suspect the level will go down after the oil circulates while running, but I also don't want to overfill.
I have attached pics for reference. The stud I reference for the clutch is at the left end of the arm and you can see the nut around it.
I also attached a pic of the dipstick.
Thanks for your time and input.
