Author Topic: Bike from scrapyard Saudi  (Read 28297 times)
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
Re: Bike from scrapyard Saudi
« Reply #50 on: January 24, 2021, 02:57:08 PM »
Brake cable stop
Offline Gamma
« Reply #51 on: January 24, 2021, 02:59:01 PM »
Another view
Offline Gamma
« Reply #52 on: January 24, 2021, 03:01:47 PM »
Oh no 🙁 Where did I put that starter motor?
« Reply #53 on: January 24, 2021, 11:49:57 PM »
I admire the systematic photographic journal of this build.
« Reply #54 on: January 25, 2021, 12:12:25 AM »
I'm sure we'll admire the result when bike is back on the road again!  ;)
Another scrapped and left to die bike getting a 2nd chance.
Offline Gamma
« Reply #55 on: January 25, 2021, 08:30:55 AM »
Thanks guys.  What I didn’t realise when starting this project is that it very difficult if not impossible to put a home build on the road in Spain.  I know it can be done in the UK, but I have discovered that General Franco I believe banned all imports of Jap bikes, so buying a CB750 in Spain that’s matriculated for the road is very expensive.
I have no papers for this bike just frame and engine numbers.
Normally to import a bike to Spain and put it on Spanish plates, requires the bike to be in standard condition.
I will build it anyway, and cross that bridge when it’s finished😀
Ive been making those d washers for the top triple tree today
« Reply #56 on: January 25, 2021, 09:08:23 AM »
Do they remember how stock should look like unless you do not change it a lot looking very special?
People at vehicle inspection here in Sweden have no clue about dual brakes at front on CB750 K0-K6. Stock only 1 as 1 example.
 If all road safety details look as a possible std bike, it can pass.
Or if they will ask for owners manual.
« Last Edit: January 25, 2021, 09:32:38 AM by PeWe »
Offline Alan F.
« Reply #57 on: January 25, 2021, 10:55:52 AM »
Offline Gamma
« Reply #58 on: January 25, 2021, 01:50:41 PM »
It won’t look standard PEWe, but that link Alan F gives me some hope. I knew that there were Cafe’d bikes in Spain, so I do think that it will be possible.  That link is very much appreciated.
After all the time working on bits overseas, I started the assembly a week or so ago.
Fitting the tyres to the wheels first.  I bought 18” front and back rims from Italy. 2.15 front and 2.50 rear.
I paid for the wheels to be laced at Central Wheel Company in the UK using stainless spokes.
I have just installed Bridgestone BT45’s. 100-90-18 and 120-80-18
You can see the spacer I’ve use on the front wheel, instead of the speedo drive
« Last Edit: January 25, 2021, 01:56:03 PM by Gamma »
Offline Gamma
« Reply #59 on: January 25, 2021, 01:54:04 PM »
Wheels. After the last shot I had to swop the discs for correct rotation.
Offline Gamma
« Reply #60 on: January 25, 2021, 02:02:40 PM »
Frame and swinging arm were powder coated by Triple S Coatings in the UK.
I am installing Allballs tapered head bearings
Remove engine from shipping box and lay in its side for installation
Offline Gamma
« Reply #61 on: January 25, 2021, 02:07:17 PM »
Engine in frame. Install triple trees and forks and Fastec brace and Tarozzi clip-ons
Offline Gamma
« Reply #62 on: January 25, 2021, 02:18:01 PM »
Some of the parts for installation.
The original sprockets had no wear on them, at least not visible. So I zinc plated them. I wasn’t sure about the possibility of Hydrogen embrittlement, so I cooked them in my oven for a few hours, straight after plating
I also installed replacement shock bushes in the swinging arm and phosphor bronze bushes
Offline Gamma
« Reply #63 on: January 25, 2021, 02:22:00 PM »
Need to put D washers in here. So I torqued to 10nm and measured the gap on both sides at 2.27mm.
So made them at 2.3mm and installed them
Offline Gamma
« Reply #64 on: January 25, 2021, 02:26:13 PM »
NGK Iridium plugs. Gapped at 0.7mm. Used nickel anti seize and a piece of fuel tubing to install and prevent cross threading
Tacho drive is blanked off
Offline Gamma
« Reply #65 on: January 25, 2021, 02:44:43 PM »
It is interesting reading the 550 build by tshrey.  I also have removed my starter, only to discover that the kick start lever hits the RH footrest and brake lever.
I heated the kickstart lever and bent it to clear the footrest, but at the moment it doesn’t clear the brake peg unless I unhook the cable.
So I’m still undecided, and may re-install the starter motor.  However, I spent ages making my own wiring loom (I’m not an electrician) from scratch and didn’t incorporate wiring for the starter.
I’m also not sure if I weakened the kickstart during the reshaping effort.
Don’t really want it to shear off and go through my calf muscle😂
Offline Gamma
« Reply #66 on: January 27, 2021, 07:17:51 AM »
Exhaust studs
Offline Gamma
« Reply #67 on: January 27, 2021, 07:20:37 AM »
Front and back
Offline Gamma
« Reply #68 on: January 27, 2021, 01:26:58 PM »
I need to make some bobbins to lift the bike at the back with a paddock stand.
Drilling and tapping the swinging arm for this.
« Last Edit: January 27, 2021, 01:28:37 PM by Gamma »
« Reply #69 on: January 27, 2021, 04:10:51 PM »
This bike is looking awesome!  Great parts choices!  Where did you get that fork brace?
Offline Shtonecb500
    • Youtube profile
« Reply #70 on: January 27, 2021, 05:36:29 PM »
So is it common running 550 calipers on 750 fork lowers? If so...I would love to do that so I can work the bolts from the front rather than the back of them.
Fastec fork brace, never heard of them but I LOVE how they look and they are not that expensive....about 150usd i think....
« Reply #71 on: January 27, 2021, 05:58:14 PM »
Shtone, 750F0/F1 and K7/8 use those calipers they look the same as 550 but do not inter-change...550 caliper must be used with 550 bracket which must be used with smaller 550 rotor
Offline Gamma
« Reply #72 on: January 27, 2021, 11:45:49 PM »
Fastec racing UK
« Reply #73 on: January 28, 2021, 01:44:21 AM »
Cool...much better looking than the Tarrozi one, but not much more expensive.
Offline Gamma
« Reply #74 on: January 28, 2021, 12:07:23 PM »
Making bobbins for stand
