Author Topic: 1969 CT-90 Float Bowl Gasket  (Read 1376 times)
Offline jakec
« on: January 27, 2021, 11:47:00 AM »
My float bowl gasket is shaped like a normal bowl gasket (see photo 1).
For some reason online I can only find gaskets that look like the one in photo 2? When searching CT-90 bowl gasket. And when looking at the fiche on CMSNL.
« Last Edit: February 05, 2021, 10:03:36 AM by jakec »
1970 CB750 K0
1977 CB750 Chop
1984 Big Twin Evo Chop
1997 XR650L
Offline Alan F.
Re: CT-90 Bowl Gasket
« Reply #1 on: January 27, 2021, 12:23:52 PM »
« Reply #2 on: January 27, 2021, 03:46:17 PM »
You certain it is a CT90 carb?!
Offline jakec
« Reply #3 on: January 27, 2021, 04:05:31 PM »
The carb is off a previously running 1969 CT90... The carb looks identical to the fiche images aside from the shape of the bowl & gasket. It has the high altitude pull knob and the integrated petcock. Just a different shaped bowl gasket and recess.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline jakec
« Reply #4 on: February 02, 2021, 10:22:48 AM »
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #5 on: February 04, 2021, 09:22:18 PM »
That's satisfying to find it,it takes a lot of searching using the part # if that's available.  8)
Offline Alan F.
« Reply #6 on: February 05, 2021, 07:58:24 AM »
I'll add the part number and photo since its a one year part and these pages come up in search engine results. Hope it helps someone later on.
Genuine Honda Carburetor Gasket Set - 16010-077-305 - 1969 CT90K1 $28.95
« Last Edit: February 05, 2021, 08:00:29 AM by Alan F. »
