Author Topic: Early cb750??  (Read 5247 times)
Re: Early cb750??
« Reply #25 on: January 30, 2021, 09:06:17 AM »
  Some fun stuff you can do will be to check the gas tank to see if its a real early one without the improved dimples for carb top clearance,long or short petcock and more once you read up at the Sandcast site. Wonder where the early #28 carbs ever disappeared to.
Re: Early cb750??
« Reply #26 on: January 30, 2021, 09:10:44 AM »
Thanks for ALL your comments. Really help me determine what to look for. I’m going to spend a few weeks doing research and making decisions. Thanks.
Re: Early cb750??
« Reply #27 on: January 30, 2021, 10:44:31 AM »
Unreal. Wow. Very happy for you. You'll be on a high for weeks during these tough times.
Does it have the thin lip alternator cover and the 9 hole clutch cover?
9 hole clutch cover. How do I identify the “thin lip” alternator cover? Thanks, J.
Offline Prospect
Re: Early cb750??
« Reply #28 on: January 30, 2021, 11:25:35 AM »
On a regular cb750 the alternator cover has a thick lip around the 9 o'clock position. The sandcast has a lip in the same position but it is only about 1/4" thick or even maybe an 1/8".
http://cb750sandcastonly.com/smf_forum/index.php?topic=348.0
« Last Edit: January 30, 2021, 11:28:13 AM by Prospect »
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Re: Early cb750??
« Reply #29 on: January 30, 2021, 11:39:10 AM »
Thanks! I’ll check t out.
Re: Early cb750??
« Reply #30 on: January 31, 2021, 02:24:49 PM »
That's an amazing find. Congrats and enjoy it. The story is, engines were taken out of line for testing or repair and returned to the assembly line later. There were occasional earlier or later number spreads. The frame to engine number spread around the 10055xx range is around 400. Seen on multiple bikes in that range.
Yep, they did that a LOT before the K4 series got it nailed down better. My own K2 (11/71 build) came with a very early K1 engine in it. I think that had a lot to do with my placing well in the old "Factory Racing" days with it. The cam was an early K1 (higher lift than K2, finally wore it down by 138k miles, though), the carbs are 657a model, spark advancer the early AD125 version, stuff like that. Inisde, it had the wire retainers on the 2 innermost steel clutch plates (until I removed them), which are rarely found at all in the 750. I sometimes wonder if it was a 'junkbox engine'? :D
And yet, they still always run well!
Re: Early cb750??
« Reply #31 on: February 01, 2021, 06:08:22 AM »
Thanks for the info. My big issue is the bike is missing the correct. Anyone have a set with 4 X throttle cable pull??
Re: Early cb750??
« Reply #32 on: February 01, 2021, 08:06:34 AM »
That was a wonderful score on finding both bikes from that seller who 'saved them' just for you,as it turns out.  8)
Offline bek1966
Re: Early cb750??
« Reply #33 on: February 01, 2021, 08:43:23 AM »
Wow, congratulations!  It's so good to see a bike like this pair up with an owner like you.  I think the bike is just as lucky it ended up in your hands  :)  Enjoy!
Brad
1971 CB750 K1 - Candy Gold
1971 CB500 K0 - Star Light Gold
1974 CB350 F1 - Glory Blue Black
Pleasant Prairie, Wisconsin
Offline Johnie
Re: Early cb750??
« Reply #34 on: February 01, 2021, 09:16:30 AM »
For sure an "UNBELIEVABLE" find. Congrats! I like the idea of keeping the patina...like on my patina candy blue/green KO which I sold last year. It looks to me like your bike will clean up pretty good. A true original when you get done with it. Great photos...thanks for exciting the forum over this neat find!
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline 69cb750
Re: Early cb750??
« Reply #35 on: February 01, 2021, 09:24:24 AM »
Carbs or cables ?
Re: Early cb750??
« Reply #36 on: February 01, 2021, 09:40:07 AM »
Here is a set on Craigslist
https://phoenix.craigslist.org/nph/mpo/d/black-canyon-city-honda-cb750-ko-carbs/7242196186.html
Re: Early cb750??
« Reply #37 on: February 01, 2021, 11:00:02 AM »
That looks like a very good deal
Offline Prospect
Re: Early cb750??
« Reply #38 on: February 01, 2021, 11:46:33 AM »
Hey John.
I know a local mechanic that has a set on the shelf. I saw them about 2 years ago but I'm not sure if they're for sale.
Current Bikes
1971 CB750K1
1972 CB750K1
1975 CB400F
Toronto Canada
Re: Early cb750??
« Reply #39 on: February 02, 2021, 06:48:15 AM »
Hey John.
Sent you a PM. Really like to know more! Thanks, JOHN D.
Offline Prospect
Re: Early cb750??
« Reply #40 on: February 02, 2021, 06:54:17 AM »
Contact info sent last night via PM.
Current Bikes
1971 CB750K1
1972 CB750K1
1975 CB400F
Toronto Canada
Re: Early cb750??
« Reply #41 on: February 03, 2021, 05:20:48 AM »
Thanks for this, I will follow up.
Offline y2kc0wb0y
  • B00msh0cka
  • Shoot the pickle....
Re: Early cb750??
« Reply #42 on: February 03, 2021, 05:44:43 AM »
everybodys dream stumbling across a sandcast,or ko !
..... for a very low price ;)
No free lunch ... will cost thousands to restore
CB750K3 890cc| 2004 VFR800A| 76 CB550F| 77 CB750F| 73 CB350G| 79 XLH| 2007 BMW R1200GS| CB750K2
Re: Early cb750??
« Reply #43 on: February 03, 2021, 07:17:46 AM »
The later and by Honda  improved versions cost less ;)
The dream is to find one in need of a normal service. Maybe derusting inside of tank, flush engine with some quick oil changes and new tires.
Som work cleaning & polishing.
Re: Early cb750??
« Reply #44 on: February 03, 2021, 07:50:05 AM »
That is the issue, parts are hard to come by and expensive when ya do find them.
Re: Early cb750??
« Reply #45 on: February 03, 2021, 07:54:23 AM »
1974 honda cb750 four SS - $3,900 (kihei)
image 1 of 2
I just saw this in craigslist here on Maui. He's saying it's a 74 but it looks like a 75. $3900 seems high.
Re: Early cb750??
« Reply #46 on: February 03, 2021, 07:55:00 AM »
It's a yellow F1
Re: Early cb750??
« Reply #47 on: February 03, 2021, 10:01:33 AM »
image 1 of 2
It is a 75 CB750SS F1.
I thought everything was expensive on the islands
https://honolulu.craigslist.org/mau/mcy/d/kihei-1974-honda-cb750-four-ss/7270627634.html
Re: Early cb750??
« Reply #48 on: February 03, 2021, 11:13:13 AM »
image 1 of 2
Chopper mentioned in that add
"Other cb750 sohc available. just ask
price from 1500 to 7000 for a beautiful chopper amen savior style plunger rear suspention ALL new, partial assembly needed"
Re: Early cb750??
« Reply #49 on: February 03, 2021, 03:00:57 PM »
So true. Today I was offered a set of very nice “28” carbs, with a matching throttle cable. They’re “very clean” Price: $4000.......! Not happening.
« Last Edit: February 04, 2021, 11:28:41 AM by BenelliSEI »
