Author Topic: CB750 Clutch Lifter Plate  (Read 1721 times)
Offline jaytee-nz
« on: February 04, 2021, 07:18:35 PM »
I bought a used complete clutch for my latest CB750 project - complete with a broken lifter plate of course !
Reading some old threads here, it's been stated that the clutch will not work properly if one of the "ears" is broken.
Mine has only broken off the very end piece, so the the spring looks like it sits ok on the remaining flat part of the plate.
So - can I use this or do I need a new one ?
Offline newday777
Re: CB750 Clutch Lifter Plate
« Reply #1 on: February 05, 2021, 09:39:07 AM »
Post a picture of the breakage
Stu
My current rides
Prior bikes....
Offline Progas
« Reply #2 on: February 05, 2021, 10:29:05 AM »
If you decide to replace it, I have several ready to go! Give me a PM if interested
« Reply #3 on: February 05, 2021, 12:09:25 PM »
Look up good-bits.co.uk for replacement lifter plates
Offline jaytee-nz
« Reply #4 on: February 05, 2021, 12:40:37 PM »
Thanks guys - I have put the clutch in the bike but the gear change can sometimes be a bit clunky and that makes me think the lifter plate could be the cause.
Just wonder if anyone has run a broken plate and whether it causes a problem or not.
« Reply #5 on: February 05, 2021, 01:01:33 PM »
 Run broken parts = expect problems. ..
Offline jaytee-nz
« Reply #6 on: February 05, 2021, 09:19:56 PM »
Yeah, kind of figured that Frank - guess I'm "clutching" at straws !
Offline Freebirdbeachbum
  • I don’t want a pickle, ...
« Reply #7 on: May 16, 2021, 12:20:07 AM »
Worst pun ever aside, You asked and answered my question and for that I thank you. I’ll never forgive you for that pun though.
1972 Honda CB 750
1980 Honda CX500 Custom
1968 Wards Riverside Benelli 125
2017 Triumph Tiger Explorer XRT
2021 Lance Havana Classic 125
1965 Moto Guzzi Lodola Gran Turismo
Offline jaytee-nz
« Reply #8 on: May 16, 2021, 02:43:19 PM »
Haha - I do like dad jokes !
In the end I removed the broken plate and had it welded. Gear change is much better now.
Offline kiwikk
  • Plumbing by Michelotti
« Reply #9 on: January 21, 2022, 10:24:40 PM »
Did you torque down the lifter plate or crank it right down to the posts like some suggest? (although I don't get how you can disengage the clutch if you've effectively negated the springs)
Offline beemerbum
« Reply #10 on: January 22, 2022, 07:19:33 AM »
Aha! The HF red bike lift! Great item for the price. Some one out there makes lifter plates from billet.
« Reply #11 on: January 22, 2022, 08:22:07 AM »
The lifter plate is supposed to touch the pillars, if the clutch is assembled properly there should still be movement left in the springs to allow the lifter plate to push the pillars and move the pressure plate at the rear.
The most common reason for breakage is althoughthe rear pressure plate can be fitted 4 ways( 4 holes and 4 pillars)  only 1 is correct and allows the pressure plate inner splines to "mesh" with the hub outer splines, if wrog the pressure plate is held off the centre efectivey shortening the pillars and making it impossible to compress the springs enough for the lifter plate to touch the pillars.
Its been a long time since i read the proper Honda manual but i think its mentioned in there, just people either dont read it or dont understand it
« Last Edit: January 22, 2022, 08:29:06 AM by bryanj »
« Reply #12 on: January 22, 2022, 10:51:56 AM »
I don't recall now what I did but I'm sure I followed the service manual's spec whatever that was.
1972 Honda CB 750
