Author Topic: Early Sandcast Found......  (Read 101070 times)
Online BenelliSEI
  • 1969 cb750
Re: Early Sandcast Found......
« Reply #1225 on: July 31, 2024, 05:26:12 PM »
Took a break today. Worked on the neglected K3 and installed “shop AC”. Hopefully the carb bodies will be ready for pick up tomorrow. I want to hear this project run again soon!
« Last Edit: August 02, 2024, 06:53:18 AM by BenelliSEI »
Online BenelliSEI
  • 1969 cb750
« Reply #1226 on: July 31, 2024, 05:48:17 PM »
DHL hit me up for extra “tax, duty and brokerage”. I will never tell what these worked out to in total! This is why I try to only deal with vendors that use USPost.
« Last Edit: July 31, 2024, 05:51:35 PM by BenelliSEI »
Online BenelliSEI
  • 1969 cb750
« Reply #1227 on: August 02, 2024, 09:30:56 AM »
Stalled out, waiting for carb bodies from vapour blaster and Yamiya seat cover kit. Repaired, polished  and waxed side covers with NOS badges. Tool kit is done and sitting in the freshly painted tray. Dismantled the original fuel petcock and compared it to several others I have. Much different casting than even my K1, so will need to restore and reuse…….
« Last Edit: August 02, 2024, 09:41:18 AM by BenelliSEI »
Online RAFster122s
« Reply #1228 on: August 02, 2024, 09:44:16 AM »
PDR guy give you update on gas tank?
Offline denward17
« Reply #1229 on: August 02, 2024, 09:44:52 AM »
Looking great John, can't wait to see pics of everything together.  Almost there.......
Online RAFster122s
« Reply #1230 on: August 02, 2024, 09:46:24 AM »
Zinc plating tool kit could bring them up nicely...just need a friend who has home plating or pick up that capability yourself this winter... Bead blaster would prep many parts as the prep before plating
Online BenelliSEI
  • 1969 cb750
« Reply #1231 on: August 02, 2024, 09:46:56 AM »
Thanks! No news on the tank, trying not to pester everybody, but I will be on the phone Monday am!
I have my own plating set up but for carbs and petcock I really just want a clean, original finish. I did watch a video on building my own vapour blaster and that may become a winter project!
« Last Edit: August 02, 2024, 09:49:55 AM by BenelliSEI »
Online RAFster122s
« Reply #1232 on: August 02, 2024, 03:53:14 PM »
I meant for the tools, not carbs...sorry I was not clear.
Online BenelliSEI
  • 1969 cb750
« Reply #1233 on: August 02, 2024, 04:40:07 PM »
Understood. The tools polished up well enough. They’re staying “original”.
Online BenelliSEI
  • 1969 cb750
« Reply #1234 on: August 02, 2024, 04:41:27 PM »
Just picked these up. They look great. Ultrasonic tank is next and then I get to “rebuild” them again!
« Last Edit: August 02, 2024, 04:43:07 PM by BenelliSEI »
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #1235 on: August 02, 2024, 07:52:36 PM »
Exciting times!
1973 CB 750 K3
10/72 build Z1 Kawasaki
Online BenelliSEI
  • 1969 cb750
« Reply #1236 on: August 04, 2024, 11:58:02 AM »
Exciting times!
Steve…… Getting closer!
« Reply #1237 on: August 05, 2024, 07:45:05 AM »
Beautiful...I love "vapor'd" aluminum
Online BenelliSEI
  • 1969 cb750
« Reply #1238 on: August 05, 2024, 01:57:05 PM »
Put two carbs through my small altrasonic, blew them clean and assembled. Was thinking of polishing the tops and float bowls but looking at them now, I think they looks just right. Probably close to the day they were new.
Got distracted by the “new to me” American Landmaster LM650. Like Sean’s (Belfast to Belfast Lone Rider) cb750 it was starving after longer wide open runs. Check my other posts for what I found….. or “how I spent my afternoon”.
Offline Honda Hansel
  • Sherwood Park AB
« Reply #1239 on: August 06, 2024, 07:16:29 AM »
Hi John
Looking good
Vapor blaster  ;D ;D ;D
Home made best tool I have in the garage
Can't be with out it
Made mine out of a Princess auto blasting cabinet (assembled with silicone sealer)no leaks
Sump pump and plastic tub with glass and blasting nozzle. Pumping the slurry up in the nozzle and using 40-60 PSI air pressure (number #3 or #5 glass )
This has been a life saver
I installed a hour meter when It was build and there is 28.6 hours on it at this time
Most used tool in the Garage
cleans every thing with out any worries of ruining the finish
Honda Hansel
Honda Hansel
#1 1977 CB750 K7 #2 1981CX500C
#3 1982 CX500TC TURBO #4 2009 KAWASAKI KLX250
#5 2017 YAMAHA 1200 TENERE
#6 2020 KAWASAKI Z900 RS SE
#7 1978 HondaCB750F project bike
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #1240 on: August 06, 2024, 07:21:36 AM »
Photos of home made blaster?
Nice looking carbs, right off the assembly line!
1973 CB 750 K3
« Reply #1241 on: August 06, 2024, 07:48:09 AM »
Carbs remind me about my K6 carbs I cleaned with plastic blast media,  fine small particles.
Found the  small blaster cabinet at my job and started to think what to put inside it ;D
This was first half of the 80's when it was OK to bring own things to my job to work on as long as it did not interfere with the job. Coffee brakes, lunch and after work OK
Online BenelliSEI
  • 1969 cb750
« Reply #1242 on: August 06, 2024, 10:54:33 AM »
New can of DOT3 in the master and bled the brakes. Nice, firm lever and all dry!
Online BenelliSEI
  • 1969 cb750
« Reply #1243 on: August 06, 2024, 10:55:51 AM »
Finished up the carbs (hopefully the last time!).
Online BenelliSEI
  • 1969 cb750
« Reply #1244 on: August 06, 2024, 10:58:40 AM »
I like to set up and test float valves and fuel levels before installation. Throttle cables and bench sync. are next…..
Online RAFster122s
« Reply #1245 on: August 06, 2024, 11:00:33 AM »
They look good John... carbs, rear caliper, and the heat shields...
Online BenelliSEI
  • 1969 cb750
« Reply #1246 on: August 06, 2024, 11:24:45 AM »
Thanks David….. Trying to stick to it.
Online RAFster122s
« Reply #1247 on: August 06, 2024, 01:30:17 PM »
How long before you load it on the trailer for the show? How many weekends you going to be out racing before then?
Online BenelliSEI
  • 1969 cb750
« Reply #1248 on: August 06, 2024, 01:43:20 PM »
5 weeks to Cobble Beach. A long break to next race, right after show.
Online BenelliSEI
  • 1969 cb750
« Reply #1249 on: August 06, 2024, 07:23:57 PM »
Thanks to “JTMARKS”. Beautifully packaged and spotless heat shields. The correct ones for early bikes, shiny but not polished. As usual, my helper was unimpressed!
