Author Topic: Early Sandcast Found......  (Read 87784 times)
0 Members and 7 Guests are viewing this topic.
Offline BenelliSEI
  • 1969 cb750
Re: Early Sandcast Found......
« Reply #1275 on: August 08, 2024, 05:03:35 am »
Glad you sorted that out, at least you had a spare to fall back on rather than sweating the problem of finding another...
The yen to dollar is more favorable lately ranging around 150 yen to a $ US. Does that mean Yamiya parts are more affordable???
Their stuff is still pretty costly, but fast shipping and quality make it good value.
Offline BenelliSEI
  • 1969 cb750
« Reply #1276 on: August 08, 2024, 05:06:43 am »
$8-9000 John
Closer….
$11000  :)
Close enough we can stop!
The total with bike purchase, right?
Yes Per. Remember this was the “parts bike” that came with the crazy chopper, so not exactly a large number! It seems, full restorations don’t get any less expensive. Rechroming original parts and professional painting of the frame etc., has made this one a little extra. A lot of hours on this one too, it’s been in the shop 2.5 years now.
« Last Edit: August 08, 2024, 05:13:36 am by BenelliSEI »
Offline grcamna2
« Reply #1277 on: August 08, 2024, 08:46:57 am »
$8-9000 John
Closer….
$11000  :)
I like the look of that nice chopper;do you think the new owner rides it,rather than just letting it sit ?
Offline BenelliSEI
  • 1969 cb750
« Reply #1278 on: August 08, 2024, 09:15:29 am »
$8-9000 John
Closer….
$11000  :)
He’s on this forum and had the engine “freshened” by Cyclex. Haven’t seen any post lately. It’s a very good looking bike, but a little weird to ride! I left it exactly the way the original owner built it in 1974. His family has a very large farm in south western Ontario, with a superb machine/workshop on the property. His workmanship and attention to detail was really exceptional. Real Time Machine.
« Last Edit: August 08, 2024, 12:53:42 pm by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #1279 on: August 08, 2024, 09:22:55 am »
Bench sync on the carbs today. First step is to set the 4 idle needles to a “T” mark on their shanks. This ensures the slides are all sitting evenly, just cracked open. Virtually impossible to measure, but they looked right. Next, set the top adjusters so each cable had between 1-2mm of slack.
The second photo shows a cable lubricator and a pair of vice grips (not clamped to the cable, just hanging as a spacer). This bit of pull sets all four slides up off the deck. In the second shot, you can see they are all a bit different height.
« Last Edit: August 08, 2024, 09:39:38 am by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #1280 on: August 08, 2024, 09:25:49 am »
#1 carb was the lowest of the four. I polished up the shank of an 11/32” drill bit and it just scraped through the opening. A very minor adjustment on the top furl nut got the other three more less equal to it. Should start on these settings.
Offline BenelliSEI
  • 1969 cb750
« Reply #1281 on: August 08, 2024, 09:30:36 am »
Here’s the set up I use to warm the intake manifolds. I leave the heater on the lower setting for about 15 minutes. It warms everything up nicely!
Offline BenelliSEI
  • 1969 cb750
« Reply #1282 on: August 08, 2024, 09:32:12 am »
Because the four cables come up through the frame, everything has to come out for the install. These carbs are a true pain.
Offline BenelliSEI
  • 1969 cb750
« Reply #1283 on: August 08, 2024, 09:35:35 am »
With the head and manifolds really warm, the carbs just pop on, with almost no effort. The manifolds are new, which really makes a difference.
Offline BenelliSEI
  • 1969 cb750
« Reply #1284 on: August 08, 2024, 09:36:30 am »
A few more items and then I may have to fire this thing up!
« Reply #1285 on: August 08, 2024, 10:35:29 am »
The heater has a disabled tip over switch, or doesn't have one, or it was bypassed or reoriented...
Yes, new carb rubbers and side cover grommets are definitely the way to go. Crazy that you got a K0 with the chopper and it has turned out so nice is a testament to your efforts and investment in effort, time, and money... Lots of sweat equity invested
Offline BenelliSEI
  • 1969 cb750
« Reply #1286 on: August 08, 2024, 12:45:06 pm »
David…. Yes. The “tip over switch” is definitely modified. It’s just a piece of duct tape. The Sandcast is a real bonus and the chopper was fun too.
Got all set to fire it up and the battery is flat. On a trickle charger now. Decided to call it a day!
« Last Edit: August 08, 2024, 12:55:42 pm by BenelliSEI »
Offline Mark1976
« Reply #1287 on: August 08, 2024, 01:30:44 pm »
Just like the kawasaki triples, a truely archaic setup. The two strokes were slightly more forgiving at and throttling off idle.
Start with the end in mind...
« Reply #1288 on: August 10, 2024, 09:07:18 pm »
That's a great idea, and one I gotta remember for the next one! When the owner wants the engine test-run it is always a wrestling match to put the carbs on. Taking them off after the run is always SO easier. I do it as soon as I can touch the head again. :D
Offline BenelliSEI
  • 1969 cb750
« Reply #1289 on: August 11, 2024, 05:01:14 am »
I rigged it up one winter when the shop was really cold. Worked so well, I use it every time. What’s really amusing is that heater belonged to my mother in law. She ran it under the card table where she played solitaire ‘til she passed at 99 years old. She smoked like a chimney. It still stinks whenever I warm it up!
« Last Edit: August 11, 2024, 07:30:58 am by BenelliSEI »
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #1290 on: August 11, 2024, 07:35:54 am »
I remember the bad old days when everyone smoked. Ugh.
The bike is a thing of beauty.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #1291 on: August 11, 2024, 07:37:28 am »
I use a heat gun I constantly move over and in the rubber boots to not heat too much.
That heater might heat more evenly without rubber burning heat.
Do not tight the clamps to much when rubber is warm and soft.
Later Honda carb boots are softer than the older shipped in transparent plastic bags with red Honda print and paper labels inside.
I have a NOS set of the older ones for K1-K6. Rubber seems to be more durable.
Another set for K0 I ordered late 80's for my K6 but got wrong model.
K0 is shorter at head spigot side.
« Last Edit: August 11, 2024, 07:49:08 am by PeWe »
Offline BenelliSEI
  • 1969 cb750
« Reply #1292 on: August 12, 2024, 09:10:01 am »
Fired it up this morning……. Ran so well I just can’t believe it! Carb sync is next. “Sh1t eating grin” for the next 48 hours!
« Last Edit: August 12, 2024, 09:12:07 am by BenelliSEI »
Offline newday777
« Reply #1293 on: August 12, 2024, 09:30:56 am »
Wahhhoooooo!
Stu
My current rides
Prior bikes....
Offline denward17
« Reply #1294 on: August 12, 2024, 09:48:34 am »
That's excellent news!
Offline grcamna2
« Reply #1295 on: August 12, 2024, 11:13:25 am »
$8-9000 John
Closer….
$11000  :)
John,the 21"? front wheel may be too large(going to an 18 or 19" fr. wheel could improve handling)and make the bike handle/corner Way Too slow,but it does add something to the 'Look'.
The frame looks like an Amen?  or did they custom build the frame also?
« Last Edit: August 12, 2024, 11:15:28 am by grcamna2 »
« Reply #1296 on: August 12, 2024, 11:32:02 am »
Bravo on the startup!
The 21" front wheel was sometimes added to help stabilize the super-long forks at speed. It's sort of a 'gyroscopic assist', so to speak. But, the extra weight of it made for wobbly steering at low speeds as the tradeoff. This then led to skinnier wheels, tires, spokes, etc. to improve the in-town riding on Saturday nights.
Offline BenelliSEI
  • 1969 cb750
« Reply #1297 on: August 12, 2024, 11:41:14 am »
$8-9000 John
Closer….
$11000  :)
Modified Amen called a “Carlini Hardhead” by Carlini Cycle Creations. I sold it ages ago to a fellow that then sold it to a guy on here! Haven’t seen any posts for a while.
Offline BenelliSEI
  • 1969 cb750
« Reply #1298 on: August 12, 2024, 11:42:58 am »
Mark….. Full points for your comment a while back on the clutch….. not releasing. I’ll give it a few heat cycles before I tear into it.
Offline BenelliSEI
  • 1969 cb750
« Reply #1299 on: August 12, 2024, 11:44:23 am »
Thanks guys! It’s super quiet, no chain noises or smoke. That’s on just the bench sync and static timing set. Vacuum gauges and timing light next time.
