Author Topic: Early Sandcast Found......  (Read 102497 times)
BallAquatics and 1 Guest are viewing this topic.
Offline CycleRanger
  • No comment about being an
Re: Early Sandcast Found......
« Reply #1325 on: August 16, 2024, 03:23:59 PM »
The license plate is from Shinjuku Ward apparently a "city ward" of Tokyo.
At least that's what Google says. A suburb from looking at the map.
Offline BenelliSEI
  • 1969 cb750
« Reply #1326 on: August 16, 2024, 05:43:59 PM »
Thanks! Next time I have it off I’ll make a note on the back.
Offline BenelliSEI
  • 1969 cb750
« Reply #1327 on: August 18, 2024, 10:27:28 AM »
“James H” provided these lovely clamps (identical to the originals) for manifolds and air box. Expensive, but worth it.
Offline BenelliSEI
  • 1969 cb750
« Reply #1328 on: August 18, 2024, 10:31:05 AM »
Been fiddling with the clutch and the plates would not break loose. Gave up and got into it. When removed, they lifted out in three separate, glued together “slugs”…… easily popped apart with a thin scraper. Clean, smooth, lubricate, reinstall. Eat, sleep, and repeat!
Getting there. Now, if I could only find my clutch centre nut socket?
« Last Edit: August 18, 2024, 11:06:51 AM by BenelliSEI »
Offline grcamna2
« Reply #1329 on: August 18, 2024, 12:01:36 PM »
How do your fiber plates look ?
Offline BenelliSEI
  • 1969 cb750
« Reply #1330 on: August 18, 2024, 12:21:22 PM »
Bill……… Sticky! Just dried up, old oil. Nothing broken off or chipped. Cleaned off two and measured them up. Both are 0.20 mm above the minimum thickness dimension and compare nicely to a new set I have. Four springs are well over the minimum free length. All the metal plates are nice and flat. They also need a good clean, but planning to reuse everything.
Found the centre nut socket, so no excuses.
« Last Edit: August 18, 2024, 12:27:13 PM by BenelliSEI »
« Reply #1331 on: August 18, 2024, 03:55:31 PM »
Glad you found the clutch nut socket...hope the clutch clean up goes well. Solvent (diesel or kerosene) or fresh oil and scrub to clean up the old oil?
Offline Kevin D
  • SE Michigan
« Reply #1332 on: August 18, 2024, 05:27:05 PM »
John, you are one persistent guy. Good enough is never good enough.
Here’s hoping that the remainder of the homestretch goes well for you, and the show.
You ought to sign your name on the bike. It’s worth more because of your efforts.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline BenelliSEI
  • 1969 cb750
« Reply #1333 on: August 18, 2024, 05:40:45 PM »
David…… Solvent on the discs and the plates need some fine sand paper too. These plates have been stuck together for at least 48 years…..
« Last Edit: August 18, 2024, 05:45:05 PM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #1334 on: August 18, 2024, 05:43:40 PM »
Kevin….. Unfortunately this one seems to need a lot of extra attention! I complain, but truthfully, I’m throughly enjoying the process.
Offline grcamna2
« Reply #1335 on: August 18, 2024, 08:40:42 PM »
That's 'the Spirit'  8) :)
Offline BenelliSEI
  • 1969 cb750
« Reply #1336 on: August 19, 2024, 11:37:47 AM »
Cleaned  the fibre plates really well, sanded all the rust and goo off the metal plates and carriers. Everything measured well above the min. specs., plates are nice and flat, so back it all went. Clean with a slight oil film. Torqued and lock tabbed.
« Last Edit: August 19, 2024, 11:46:02 AM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #1337 on: August 19, 2024, 11:39:48 AM »
Buttoned it all up. Cable installed and actuator adjusted, all works as it should.
This part of the project is 100% done. Seat and tank to finish the job……..
« Last Edit: August 19, 2024, 06:06:47 PM by BenelliSEI »
Online newday777
« Reply #1338 on: August 19, 2024, 11:51:27 AM »
Well done!
Stu
My current rides
Prior bikes....
Offline BenelliSEI
  • 1969 cb750
« Reply #1339 on: August 19, 2024, 12:42:37 PM »
Thanks Bill and Stu. I’ve managed to spend a bit more time and money than usual on this one! I think the final outcome will be worth it.
A few small bits, including the tank chrome strips, arrived this aft. Ordered from Yamiya about six days ago. Great service!
« Last Edit: August 19, 2024, 12:53:57 PM by BenelliSEI »
« Reply #1340 on: August 19, 2024, 01:10:17 PM »
Well, while you may have spent a bit more on the bike the Sandcasts are worth 2-3x or more than the run of the mill cb750k. It's value only increases unless the bottom falls out of the market, then it's value relatively speaking remains the same or still increases based on rarity.
You have done a great job with this one. Hope your PDR guy comes through with great results too.
« Last Edit: August 19, 2024, 04:48:17 PM by RAFster122s »
Offline BenelliSEI
  • 1969 cb750
« Reply #1341 on: August 19, 2024, 01:46:13 PM »
Well, while you may have spent a bit more on the bike the Sandcasts are worth 2-3x or more than the run of the cb750k. It's value only increases unless the bottom falls out of the market, then it's value relatively speaking remains the same or still increases based on rarity.
Thanks David. I talked to him this am and he still hasn’t done it! Lit a fire under him! In addition to the seat building, I also have to remember to pick up the original petcock from the guy that vapour blasts for me. It’s totally unique to the first bikes and I want to rebuild it and install it back where it belongs…..
« Last Edit: August 19, 2024, 06:06:02 PM by BenelliSEI »
Offline grcamna2
« Reply #1342 on: August 19, 2024, 09:03:28 PM »
John,it might be nice if you had a 'friend' who might go volunteer to help the PDR guy finish some of his current projects: in care of John.  :D   ::)
Who would turn down free,qualified labor?  :D  Because you're such a nice person.  ;)
« Last Edit: August 19, 2024, 09:06:05 PM by grcamna2 »
Offline 69cb750
« Reply #1343 on: August 20, 2024, 04:31:10 AM »
Chrome carb boot clamps are 17255-300-000
Zinc air cleaner clamp is 17255-230-000
Direct from James or website ?
Offline BenelliSEI
  • 1969 cb750
« Reply #1344 on: August 20, 2024, 04:46:30 AM »
I ordered them (and a set of carb top gaskets) from his site.
« Last Edit: August 20, 2024, 04:49:07 AM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #1345 on: August 20, 2024, 04:47:27 AM »
Honestly…. After the conversation yesterday, I only want to hear from him one more time. He’s the only guy in Ontario that would do a motorcycle tank. Wish I’d just posted it off to someone more reliable.
Offline 69cb750
« Reply #1346 on: August 20, 2024, 06:00:20 AM »
Where is it ?
Offline BenelliSEI
  • 1969 cb750
« Reply #1347 on: August 20, 2024, 08:55:32 AM »
Where is it ?
www.carbclamps.com
« Last Edit: August 20, 2024, 08:58:18 AM by BenelliSEI »
« Reply #1348 on: August 20, 2024, 10:35:27 AM »
Where is it ?
www.carbclamps.com
OK price for those very special parts I must say.
Good service to make them for old bikes in need ;)
Offline BenelliSEI
  • 1969 cb750
« Reply #1349 on: August 21, 2024, 01:49:59 PM »
Early this morning I had a good long look over the S/C. Ended up working on my much ignored cb750K3. It needed a RHS bar switch replaced and the starter motor safety switch bypassed (it’s been behaving wierdly for a while). There is nothing left to do on the ‘69. Called my buddy Terry and heading to his place on Friday morning to tackle the seat rebuild.
Celebrated by taking the K3 for a nice ride, followed by a swim in our pond.
« Last Edit: August 21, 2024, 01:51:46 PM by BenelliSEI »
