Author Topic: Early Sandcast Found......  (Read 101290 times)
Re: Early Sandcast Found......
« Reply #875 on: February 16, 2023, 12:19:56 PM »
Great work, very impressive! I need a sandcast to round out my collection. So far I only have a low 3 digit motor on a stand in my rec. room.  :)
Cliff…….. Don’t give up! I never expected to find one and then it magically appeared!! What number is yours?
« Last Edit: February 16, 2023, 12:21:58 PM by BenelliSEI »
« Reply #876 on: February 20, 2023, 03:07:33 PM »
I’d like to see a picture of that!
« Reply #877 on: February 21, 2023, 08:47:55 AM »
+1!   Pics or it didnt happen!  If I didnt know better, I'd say he must be single!
« Reply #878 on: February 21, 2023, 08:56:14 AM »
He has a rare wife…
Friend who lives in Utah, his wife is an AHRMA racer and has been for decades. They have a collection of bikes on display around the house. Lots of interesting old race bikes of note mostly…not bikes Beth has raced, but significant bikes.
I know several guys who bought the replica CR racer that was 50cc dohc design had them on display in their house. Musselman Honda here in town has one on display and some dickhead stole the gas cap off it!
(Honda cb50r)
BaT sold one recently for $13750
https://bringatrailer.com/listing/2004-honda-cb50r-4/
Mecum sold one in 2018 for only $7700
« Last Edit: February 21, 2023, 09:18:27 AM by RAFster122s »
« Reply #879 on: February 23, 2023, 05:59:57 PM »
Wanted to get back on this today. Spent the entire day moving snow!! Maybe tomorrow......
« Reply #880 on: February 24, 2023, 01:17:39 PM »
Pistons cleaned up today. New ring gaps were all less than 1/2 the wear limit gap (I’m reusing original std. pistons with new std. rings in the very lightly honed, original bores). The three piece oil rings in my new RK set  did NOT fit in the pistons. Measured up the original (single piece) oil rings and they too were less than half the wear limit gap. They are going back in..... Not “best practice” but moving ahead.
The 12 X 22 mm dowels that are suppose to go between the barrel and head are way too long, for this early motor. Fortunately I have a shorter set in a “bin”. Same as the ones that connect the case to barrel.
« Last Edit: February 24, 2023, 04:33:00 PM by BenelliSEI »
« Reply #881 on: February 24, 2023, 01:37:50 PM »
That is one wild 50cc motor.
« Reply #882 on: February 27, 2023, 11:42:21 AM »
Thankless morning cleaning the top of the case, in prep for the barrel. Walked away and will do it all again tomorrow. Diving through stacks of collected gaskets, I think I will use this old, made in the USA, Best Gasket Set.
« Last Edit: February 27, 2023, 11:44:37 AM by BenelliSEI »
« Reply #883 on: February 28, 2023, 01:33:03 PM »
Guess who once fired a piston pin clip into the sump?
Offline denward17
« Reply #884 on: February 28, 2023, 02:16:17 PM »
Looking good, hope you didn't fire that clip into the sump today....
« Reply #885 on: February 28, 2023, 05:47:47 PM »
Nope…… had it well “covered”!
« Reply #886 on: February 28, 2023, 07:07:10 PM »
At least you aren't needing a new gasket to split the cases, just a new thin layer of Threebond. Not that splitting the cases is enjoyable, at all for such a mistake...
« Reply #887 on: February 28, 2023, 08:36:55 PM »
It happened once, +25 years ago! Got with a small telescoping magnet...
« Reply #888 on: March 01, 2023, 11:22:40 AM »
Spent the morning setting up the top end build. My buddy Gary comes from Toronto, one day a week, for a “shop day”. Was going to leave it until he showed up, but it magically slid together! Came up to the house to re-read torque procedure notes from PeWe and Hondaman..... Picture later.
« Last Edit: March 01, 2023, 01:30:11 PM by BenelliSEI »
Offline denward17
« Reply #889 on: March 01, 2023, 11:36:40 AM »
Awesome, I was doing the same today.  I hope to start putting in cam towers/cam tomorrow.
« Reply #890 on: March 01, 2023, 01:15:48 PM »
Well done. I wonder why the guys all pull down so hard? All my manuals suggest 15.9 ft.lbs. for the main head nuts. I used 16 and it seemed plenty! We’re going away for almost 6 weeks, so I think I may just stop and retorque when we return. I’m determined not to rush this one.....
« Last Edit: March 01, 2023, 01:24:36 PM by BenelliSEI »
« Reply #891 on: March 01, 2023, 01:18:22 PM »
I had to turn down both ends of a 10mm deep socket to get to the outside “barrel screws”. The machined bore holes, down through the head casting, on this early engine, are MUCH smaller than any other I’ve built before. Usually one of my 1/4” drive sockets will drop in there. Not this one!
« Last Edit: March 01, 2023, 01:29:19 PM by BenelliSEI »
Offline denward17
« Reply #892 on: March 01, 2023, 02:43:11 PM »
Fortunately, my deep 10 mm socket would fit down to the 6mm bolts.   I also wonder why some guys go so tight on the head bolts, I stopped at 18ft lbs.
I'm glad, cause I don't have a lathe to fix 'em.   8)
« Reply #893 on: March 01, 2023, 04:07:18 PM »
I’ll probably go +1 on the retorque, but I never touched the studs so not looking for trouble!
The Sandcast has very small holes, none of my sockets were even close.
Online Don R
« Reply #894 on: March 01, 2023, 05:27:23 PM »
 My next diecast engine has 5/16" allen bolts where the 6mm's were.
« Reply #895 on: March 02, 2023, 05:55:58 AM »
I’d think a replaceable stud would be good too?
« Reply #896 on: March 02, 2023, 07:18:02 AM »
Is there a helicoil or similar to revert to 6mm?
« Reply #897 on: March 02, 2023, 11:33:01 AM »
Ny K2 head has very tight holes for the M6 bolts under the coins.
1/4" 10mm socket could not get in there.
I used allen heads of same lenght with washers. Then no problem to tighten with my 1/4" torque wrench.
Stock bolts have JIS on hex head.
Early too? Then use a JIS on extension rod to wrench.
« Reply #898 on: March 02, 2023, 11:58:20 AM »
Here’ s my very early cam cover (known as a “waffle” cover as there are several “X” shapes cast on the underside). Some real differences I noticed when comparing to several others I have in the “spares”. There is no lock tab under the bolt that retains the tach drive shaft. I will fit one! Also noticed that all my covers have a date stamp inside. Never noticed this before.
Clearly date stamped April 8, 1969. Three weeks before my 16th Birthday.......
« Last Edit: March 02, 2023, 04:44:58 PM by BenelliSEI »
« Reply #899 on: March 03, 2023, 07:55:26 AM »
Pulled the sump off today. No debris and the oil pump pickup screen is spotless. Primary chain is nice and tight. Great!
