Got the “tank hold down table” almost finished today. This is all so the Paintless Dent Removal guy can work his magic.
Started with an old piece of 1” counter top (the cutout for a stainless steel sink) that came from my scrap wood pile. Mounted a full length of 2” X 4” piece of lumber to the underside, so the plate can be fixed in a vice or WorkMate style clamping bench. To ensure a wobble free fit I took a cut off the top side of the 2” X 4” and glued and screwed it down.
Next I shaped a 1” pine board to fit tightly wedged in the underside of the tank. Mounted it to the main table, so as I push the tank towards the rear of the table it jams into the wedge and prevents the tank from any side movement.
Finally “Magivered” a T shaped piece of hardware that mounts the two front rubbers in the tank cups. Attached a turnbuckle that can be snugged up to push the tank down and back, tightly into the wedge!
Final challenge is to hold down the back of the tank securely (where the rubber tank strap usually goes). I was about to drill a hole in the tank bracket and drive in a big screw, when I decided to pause for the day.
In the photos, the table is clamped to a vice, so I can spin it around. Interestingly, when I tried a K1 tank on the table, the wedge piece is far too small. The “Wrinkle Tank” is much tighter to the bike frame. It must hold a lot more fuel than the later tanks…..
