Author Topic: Early Sandcast Found......  (Read 98737 times)
Online BenelliSEI
Re: Early Sandcast Found......
« Reply #1400 on: August 29, 2024, 01:23:09 PM »
Per….. I have not got into them. Will report when I do.
The tank is derusting for 24 hrs. Everyone is coming for the long weekend. School starts Tuesday here. Got the bikes running and ready to go for the g’kids! The RM80 had a plugged jet. Rode it once around, that thing is lethal!
« Last Edit: August 29, 2024, 06:35:11 PM by BenelliSEI »
Online BenelliSEI
« Reply #1401 on: August 29, 2024, 01:23:44 PM »
Oh.....that flat tire seat......
Now isn't so original John! What would Frank say????
Me? I like it soft and restored for the butt.
You are doing a fine job on it.
Thanks! I agree. The foam was so shot it left a trail wherever it went!
« Last Edit: August 29, 2024, 01:34:10 PM by BenelliSEI »
Online BenelliSEI
« Reply #1402 on: August 29, 2024, 07:24:23 PM »
Tank sat all day, filled with phosphoric acid (Stearn’s Milkstone Remover and water @ 8:1) and leaving it over night. The “wrinkle tank” portion I can see just below the cap is already rust free. Definitely going to install a pair of small, well hidden inline filters for the first few tanks of gas!
« Last Edit: August 29, 2024, 07:26:11 PM by BenelliSEI »
Online BenelliSEI
« Reply #1403 on: August 30, 2024, 11:38:51 AM »
Flushed it out with a high pressure water and threw in some diesel fuel/ two stroke oil mix. Shake and drying in the sun. Not absolutely perfect, but moving ahead!
Offline 71 V12
« Reply #1404 on: August 31, 2024, 02:00:23 AM »
I would be really interested in the type of filter to use and the correct fuel line routing for K0.
Online BenelliSEI
« Reply #1405 on: August 31, 2024, 05:46:44 AM »
I’m sure it’s not “correct”, but it works. I’ll post a pic when I get to it. The family is here for the long weekend…….
« Reply #1406 on: August 31, 2024, 07:44:04 AM »
Very fine powder passing the strainer?
The filter in the petcock work fine on my 2 bikes. The earlier 2 piped petcock. But not old, ordered 2013-2017.
I have a feeling that dirt will come with fuel from the gas station.
As here. No fuel starvation.
My K2 had fuel issues. It was the soft stock type non braided fuel hose from Yamiya.
It can be bent so fuel will starve.
Close to where connected on carb pipes that can be angled wrong. When adjusting air screws, move hose away for easier acccess.
Hose can be a little nicked, enough to act as too small main jets
Before checking low float level or go bigger on main jets, check fuel hose routing.
« Last Edit: August 31, 2024, 07:50:20 AM by PeWe »
Online BenelliSEI
« Reply #1407 on: August 31, 2024, 05:43:55 PM »
The tank on this ‘69 has not been used for +48 years. I’ve cleaned and flushed it over and over but I’m sure there is still some fine “silt” in it. The petcock has all new parts, including a screen and internal “0” ring. I’m planning to hide two small inline filters between it and the carbs. I run a set on my K1 and have never had any difficulty with fuel flow. Will post some pictures when I get to it.
« Last Edit: August 31, 2024, 06:54:45 PM by BenelliSEI »
Online BenelliSEI
« Reply #1408 on: September 01, 2024, 05:49:58 PM »
Working on the tank finish today and realized the two NOS badges I have are for a 1971! Add refurbishing the originals to my “to do” list……
« Reply #1409 on: September 01, 2024, 06:11:05 PM »
Oops
« Reply #1410 on: September 02, 2024, 06:14:59 AM »
K1 tank badges look fine, golden relief.
« Reply #1411 on: September 02, 2024, 07:41:05 AM »
Can you post a photo of the two types of tank badge?
Online BenelliSEI
« Reply #1412 on: September 02, 2024, 10:21:56 AM »
Steve…… On post 1385 you’ll see the wrong one. I put it on for the photo. It’s white with gold border and should be on my K1. Here’s what I dug out for the SC. I’ll clean them up and touch them up. JTMarks has a set on EBAY, but they are repros. These are originals. One was actually on the bike when I started……
« Last Edit: September 02, 2024, 10:30:22 AM by BenelliSEI »
Online BenelliSEI
« Reply #1413 on: September 02, 2024, 10:25:35 AM »
Someone asked about the small inline fuel filters? Here’s the pair I’m using on this for a while…… For some reason, lots of people have trouble when they install them. I’ve had a set on my K1 for a few years and they work fine. Despite my best efforts, I’m sure there is still some crap in this 55 year old tank. Bit of extra insurance. Carbs are spotless and I want them to stay that way! When the “belly” of the filter darkens up, time to change them out.
« Last Edit: September 02, 2024, 10:29:33 AM by BenelliSEI »
Offline CycleRanger
  • No comment about being an
« Reply #1414 on: September 02, 2024, 10:28:02 AM »
I believe the early badges are slightly shorter in length than the later badges.
Online BenelliSEI
« Reply #1415 on: September 02, 2024, 10:37:07 AM »
I’ve never measured. I will.
Online BenelliSEI
« Reply #1416 on: September 02, 2024, 01:25:29 PM »
You are correct! About 8mm.
Online BenelliSEI
« Reply #1417 on: September 02, 2024, 01:26:47 PM »
The list is getting VERY short. Tonight I need to touch up the badge for the other side of the tank…….
« Reply #1418 on: September 02, 2024, 04:24:17 PM »
"For some reason, lots of people have trouble when they install them."
How they have run the fuel hoses is usually the problem,  not having an all downhill slope without any uphill to get to the carb inlet tees. I've seen hoses that dipped below the inlet tees and bowls to put the filters on the backside of the carbs. You have properly run your hoses John havingthefilters up on top(hopefullythey don't get vapor lock from the heat that close to the head).
Putting the hoses below the bowls is a problem in the waiting to interrupt the flow of gas, especially at speed.
Online BenelliSEI
« Reply #1419 on: September 02, 2024, 06:48:58 PM »
Stu….. Understood. I actually added a small (invisible) tie that keeps the two lines and the filters, closer to the carbs than the head. It does keep everything running downhill all the way. Using that good Honda hose helps. Nice gentle bends ensures no restriction by the hose too. When the petcock bowl runs clean, I’ll definitely remove those extra filters.
« Reply #1420 on: September 02, 2024, 08:37:12 PM »
Offline 71 V12
« Reply #1421 on: September 03, 2024, 09:03:48 AM »
Thank you for posting the photos of the fuel line routing, just seems odd that the lines are not retained by anything and so close to the choke operating mechanism.
Very discreet little filters, I have looked but can’t find them. Would you be able to post a link?
Regards,
Kevin
Online BenelliSEI
« Reply #1422 on: September 04, 2024, 05:25:35 AM »
Kevin…… I pick the fuel filters up at a local lawn mower/ small engine repair shop. The guy keeps a box of them on the counter and gives them away to paying customers or $0.99 each.
The lines lay nicely in place, because they are new, Honda hose. I also have an invisible tie holding the one from carbs #1 and #2 down against the carb plate so it can’t get near the choke mech.
Online BenelliSEI
« Reply #1423 on: September 04, 2024, 05:30:41 AM »
Yesterday I had to correct my own stupid mistake. When I added fuel to the tank, my painstakingly restored petcock started pissing fuel everywhere. And not just a bit. Cleaned up and opened it up to see what faulty part was to blame.
Imagine my surprise when I found the “wavey washer” UNDER the lever disc instead of ON TOP of it. There’s an idiot in my shop and apparently it’s me!
Good news is I’m done.
« Reply #1424 on: September 04, 2024, 08:23:59 AM »
I would have to think long and hard about removing that dent..
 Every mark on an original bike had a story, part of its life.. it adds character. . And it reflects it being used..And a life lived..
 A shiny restored bike.. it just looks new and perfect.. no stories.. sort of sterile. . Almost like kept in a box and not taken out..
 Ever take a look at early original bikes from the 20,s and down... usually worth more than the restored ones..
 So yeah on this one , you can harm the value by restoring it, plus  deplete your savings.
Even though Frank did not want the dent removed, it was the right thing to do and he would now approve!
Great job, John....start to finish 3 years, 6 months [with breaks]
