Author Topic: Early Sandcast Found......  (Read 98784 times)
Re: Early Sandcast Found......
« Reply #1550 on: October 29, 2024, 01:11:38 PM »
Are you keeping it? (the Sandy)
Yep….. This winter I plan on fitting an original air box (after lots of repair) and the 4-4 pipes that came on it. Remarkably they don’t have a single dent. The lower right has a small hole where the head pipe meets the muffler, but I think I can weld in a small patch. It’s so hidden, I doubt it will ever be seen. They should clean up very well. The bike would then be +95% original!
« Last Edit: October 29, 2024, 01:14:37 PM by BenelliSEI »
« Reply #1551 on: October 29, 2024, 09:27:31 PM »
Have you looked how the diffuser/baffle look like when taken out?
« Reply #1552 on: October 30, 2024, 06:30:26 AM »
I did. They match the ones I got with my Yamiya “no number” pipes. I’ll post a picture when I get started.
« Reply #1553 on: October 30, 2024, 06:31:26 AM »
Per, I did. They look the same as the ones I got with my Yamiya “no number” pipes. I’ll post a picture when I get started.
Online Don R
« Reply #1554 on: October 30, 2024, 04:00:20 PM »
 I was looking at my original sandcast airbox a few minutes ago, later I found a piece of it on the floor. I was also wondering what to do about the hard intake funnels.
 Did you ever try the 5 step adjuster to 3 step adjuster shock swap? I have a few with the 3 step adjusters only one set shows 7 coils below the cover though.
« Reply #1555 on: October 30, 2024, 04:52:20 PM »
Don….. the intake stacks on this air box were rock solid! I used my “paint stripper” air gun and blew it through them (one at a time) until they were just shy of melting. Using a pair of thick gloves, they folded up like hot toffee and came out easily. I’m using this new (to me) JBWeld product and repairing one piece/ crack at a time and then reinforcing from the inside. Seems extraordinarily strong so “sticking with it”. Just ordered another one from Amazon.
I have the three step ring sitting on my bench and will try that swap soon. I’ll post the outcome. Measuring carefully, the old one seems like it will be tight. Might work?
« Last Edit: October 30, 2024, 04:55:47 PM by BenelliSEI »
« Reply #1556 on: November 12, 2024, 07:38:45 AM »
In the final rush to get this motorcycle ready for “Cobble Beach” I discovered the new  17T drive sprocket I had in my stash didn’t fit. The 16T that was on the bike was much narrower than the new one. The 17T had the raised section in the middle, on both sides. Machined one side off and hopefully it will now have the clearance it needs and align correctly.
« Reply #1557 on: November 12, 2024, 12:42:28 PM »
Got it in today. Turned out to be a bit tricky. My new riveted chain just had to go on the sprocket before sliding it onto the output shaft and the clearances were VERY close. Lined it all up and gave it a little tap using a brass drift. Luckily it popped in without too much cursing. One more thing back “as it should be”……
I suspect the new chain (HD, non “0” ring) is a bit beefier than in 1969. Close tolerances require a small modification to the sprocket cover. Completely eliminated the lubricator. All good.
« Reply #1558 on: November 12, 2024, 07:46:01 PM »
I always thought sandcasts had 16/46 tooth sprockets?
« Reply #1559 on: November 13, 2024, 01:12:25 AM »
Yes 16 tooth up to engine vin 3527 (#18 in the list of differences)
https://cb750sandcastonly.com/smf_forum/index.php/topic,217.0.html
Offline 69cb750
« Reply #1560 on: November 13, 2024, 04:26:16 AM »
During the chain, sprocket, clutch spring, real wheel damper recall all bikes got a 17t sprocket.
23801-300-315 was used on engines to #3527 (never seen one)
23801-300-010 was used on engines after #3527 (sprocket has shoulder both sides)
« Reply #1561 on: November 13, 2024, 05:34:48 AM »
Gentlemen…… I did NOT know this. All the charts I have suggest 17T for 1969-71. I assumed someone had swapped in the 16T! Mmmm. Put it back?
Offline 69cb750
« Reply #1562 on: November 13, 2024, 06:12:07 AM »
I would use 17 tooth, the 16 tooth was a factor in chain failures.
Post a message on the sandcast board, ask for 16t photo.
« Reply #1563 on: November 13, 2024, 06:14:37 AM »
I’ll leave it. I have the 16T that was on the bike (excellent condition).
Will post a photo later. Thanks!
« Reply #1564 on: November 13, 2024, 06:41:12 AM »
I broke a chain on my K0, not a sandy. It was a bummer back then.
« Reply #1565 on: November 13, 2024, 06:44:47 AM »
Steve…… I installed new chain and sprockets. The 17T creates a larger turning radius for the chain. I had to slightly modify the cover to clear it. I think I’ll put the 16T in the “original parts” bin and leave the 17T installed. Mostly because with the endless, riveted chain it is a real fiddle to get the 17T on and off! Screw it.
Offline lash
« Reply #1566 on: November 13, 2024, 07:09:04 AM »
17t will also reduce your cruise rpm by about 400 vs the 16t.
« Reply #1567 on: November 13, 2024, 09:53:04 AM »
Even better!
« Reply #1568 on: November 13, 2024, 09:54:43 AM »
And probably no judge will ever know.
« Reply #1569 on: November 13, 2024, 10:01:42 AM »
Stu….. Not without “X-Ray Vision”! Here’s the very early 16T, in excellent condition. Nicely supports the indicated 17,628 original miles.
« Reply #1570 on: December 13, 2024, 12:58:11 PM »
Cleaning up a few details on this project. Has anyone bought the “black top” shocks from Yamiya? I asked them this question, but no answer. Do they have five preload steps on the adjuster or three steps like the originals?
The replicas I bought locally have five and not quite “correct”……
« Reply #1571 on: December 14, 2024, 07:21:39 AM »
Looking for your own Sandcast?
Very well preserved, low number bike for sale in Canada. Fairly priced.
Visit the Canadian Vintage Motorcycle Group website at CVMG.ca
Check out the ads, “Motorcycles for Sale”. About US$20K.
« Reply #1572 on: December 15, 2024, 06:43:10 AM »
From the photos of the shocks on Yamiya they appear to be 3 position.
« Reply #1573 on: December 15, 2024, 10:00:00 AM »
Steve….. I thinks so too. Just would like some one to confirm before I try a set.
Offline Laids
« Reply #1574 on: December 15, 2024, 04:56:09 PM »
What was the timeline for the 3 position shocks. The K1 I’m currently working on came with 3 position shocks with the decals faint.
