Author Topic: A new triple?  (Read 2796 times)
A new triple?
« on: February 09, 2021, 04:02:47 PM »
 I saw some pics on FB from cycle X, built by Kiyo?  There may be a new triple engine sohc4.
https://www.facebook.com/cyclex/photos/pcb.4250835418277771/4250790118282301
  • Moderator
Re: A new triple?
« Reply #1 on: February 09, 2021, 04:32:14 PM »
Wow Don, where did this spring up from, it looks like a clone of the AT&SF apart from not being fuel injected ?
Offline gschuld
Re: A new triple?
« Reply #2 on: February 09, 2021, 06:26:39 PM »
That is almost certainly a Kiyo Garage build.  More show bike than anything.  Kiyo did some land speed runs on his double too. Notice the A/G 3000.  That’s salt flats speak for Altered chassis, gas fuel, 3000cc limit(largest allowed at Bonnville)
That bike is running all 3000cc into a factory trans.  That bike won’t be doing drag launches....
The last even double drag bikes using the factory rear engine trans was the 1972/3 RC series before Byron built the Lenco trans Vance and Hines double.  The RC build Bob Steakley double held 5 national records with the factory rear trans before the V&H monster took over.
Beautiful build. But that trans can maybe handle N/A gas land speed (gentle acceleration), but little more.  No nitro, staging with alcohol before launching on a 10” slick shenanigans
Very cool though.  The pipes are very Action Fours 2x4 esque
George
« Last Edit: February 09, 2021, 06:30:20 PM by gschuld »
Offline gschuld
Re: A new triple?
« Reply #3 on: February 09, 2021, 06:31:55 PM »
Unmistakable family resemblance 👍
Offline gschuld
Re: A new triple?
« Reply #4 on: February 09, 2021, 06:40:13 PM »
Old photo:  RC Engineering built Bob Steakley double engine dragbike at Bowling Green Kentucky 1973
It broke a national ET record in qualifying with Russ Sr at the helm at its first race event.  It was the best of the last of the breed using the factory rear trans.
George
Offline gschuld
Re: A new triple?
« Reply #5 on: February 09, 2021, 06:54:11 PM »
Looks like a Goodyear Eagle 28 4.5 15 land speed tire on the rear and no front brakes.  All the details one would expect for a salt flats/El Mirage land speed runner.
Awesome..... go Kiyo
George
Re: A new triple?
« Reply #6 on: February 09, 2021, 07:28:19 PM »
Second last photo reminds me of a dragbike called BUZZSAW..
Offline turboguzzi
Re: A new triple?
« Reply #7 on: February 09, 2021, 11:59:56 PM »
and i thought from the title that someone chopped off a cyl from a four :)
Offline simon#42
  • liverpool
Re: A new triple?
« Reply #8 on: February 10, 2021, 12:22:18 AM »
So did I
Offline johno
Re: A new triple?
« Reply #9 on: February 10, 2021, 12:54:57 AM »
Thanks for the pics George, 1972 was a good year for me, bought my first K2 ( still got it)
I hope Kiyo has big balls and Evan bigger ticker  ;D
Offline gschuld
Re: A new triple?
« Reply #10 on: February 10, 2021, 03:33:25 AM »
Kiyo is known for his show bikes. Lots of bling and intricate multi color candy paintwork(by Ca painting legend Bill. Carter).  And he also happens to like cb750s and has a shop in Gardena, Ca.  Same neighborhood as the old RC Engineering shop, ISkY cams, and so many other Hot Rod businesses.  El Mirage lake bed land speed racing is less than a 2 hour drive from Kiyo’s shop. That’s where he first tested the double.  Then he went to Bonneville.  Probably safe to say that he built a show bike and took it land speed racing rather than built  a full on land speed bike and tried to make it photogenic.
Probably the same plan for the new triple. FWIW, a Kawasaki multi engine holds the AMA 3000cc A-G (N/A, gas fuel, custom chassis, no fairings) record dating back to 1976 at 187mph.  That triple might be putting out up to 325 total RWHP or so N/A on race gas assuming he built some robust, but not totally exotic 997cc 71mm bore engines.
Mike, did you send Kiyo two sets of those beautiful CNC chopped cases for his build?  If not I’m sure he would have wanted to know about your work there.
George
« Last Edit: February 10, 2021, 03:44:26 AM by gschuld »
Offline sohc boy
Re: A new triple?
« Reply #11 on: February 10, 2021, 05:04:59 PM »
 :) :) :) nice
i live by the voice inside my head
Offline johno
Re: A new triple?
« Reply #12 on: February 12, 2021, 07:31:22 PM »
Come on Pete, drag yours out and finish the job. My offer to do the engines still stands, you do everything else  ;D
Would be good noise therapy for you to go outside after a barney with the missus and start the beast up  8)
I noticed he runs the front oil pump off the maggy drive, haven't seen that before, all the twin engined bikes I seen front pump was run off the camshaft.  Also don't want to sound dumb but on Kenny's cycle X drag bike what does he use the two inspection covers fabbed up on ends of his tappet cover,  I assume they are to do with changing or adjust cams, anyone know ? I was hoping it was because he had to machine cam mounts and rocker positions to stand up his valve angle, but that's a lot of work.
cheers johno
Re: A new triple?
« Reply #13 on: February 13, 2021, 05:21:38 AM »
George
No George.....those cases were proprietary RC parts. ;)
Offline gschuld
Re: A new triple?
« Reply #14 on: February 13, 2021, 07:19:17 AM »
George
Proprietary RC parts?  🤷‍♂️  Did you send the discarded silicon special case halves over to Kiyo?🤣
George
Offline sohc boy
Re: A new triple?
« Reply #15 on: February 13, 2021, 04:42:03 PM »
cheers johno
... ah maybe one day Johno , its been hanging on the wall for few years now , having hard time getting one engine bike up n running again let lone the double .... yes not real sure either Johno on Cycle X bike
Re: A new triple?
« Reply #16 on: February 14, 2021, 04:52:21 PM »
 The mini sprint car guys ran their injection and oil pumps off the cam. I got into a shop full  of that stuff once when I couldn't afford to buy any of it. It was cool to look at, the guy even had a race ported big valve sandcast head. Every thread in it was helicoiled. I bought what I could regret not borrowing some $$ and loading a truck.
Re: A new triple?
« Reply #17 on: February 15, 2021, 09:39:26 AM »
I thought it was a new, retro Kawasaki!
Offline gschuld
Re: A new triple?
« Reply #18 on: April 11, 2021, 06:21:47 AM »
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
Re: A new triple?
« Reply #19 on: April 11, 2021, 07:17:29 AM »
Such a visually stunning piece of mechanical art. Nice article link George. What's not to love about the phrase  "extensive drillium"   ;D ;D ;D
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
Offline Old Scrambler
Re: A new triple?
« Reply #20 on: April 11, 2021, 03:16:27 PM »
VERY NICE...............but more drilling will be required for a few yards of safety wire ;D
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Re: A new triple?
« Reply #21 on: April 11, 2021, 05:30:54 PM »
Beautiful piece of art work. Too bad he only mildly built the engines to 836 and did not take full advantage of the 3000cc class limit. However I doubt it will actually see the Salt. I do hope to see the bike there and meet this artist.
  • Moderator
Re: A new triple?
« Reply #22 on: April 11, 2021, 06:21:00 PM »
Don and George, copying is the ultimate form of flattery. (is that's the right word).
If this bike runs 7s, it's a good copy but I doubt it will get anywhere near it.
Offline BPellerine
Re: A new triple?
« Reply #23 on: April 11, 2021, 06:23:58 PM »
anyone see the extended clutch housing!
1978 CB 750K ard and webers
another anfob
Offline gschuld
Re: A new triple?
« Reply #24 on: April 11, 2021, 07:29:56 PM »
You should give Kiyo more credit.
