Author Topic: New Spokes for K0 Wheels  (Read 1399 times)
« on: February 19, 2021, 08:31:15 AM »
Searching for spoke sets for my ‘69 K0. General consensus for Sandcast is the nipples should be “gold”. All the spoke sets I have (and used in the past) are “silver”. Anyone have a source that comes with gold/ yellow plated nipples?
Re: New Spokes for K0 Wheels
« Reply #1 on: February 19, 2021, 08:33:49 AM »
Will the originals  clean up somewhat ?
 ANY  non original parts won't helpthe value of the bike any..
 Won't hurt to post a measurement   including diameter, or you end up with gold ones that are not quite right..
 I still have a half bag of original Torrington nipples for Schwinn and other makes. They are from the 40,s or 50,s , but the correct long 2 flat nipples...... they sell like crazy when I put them up for sale, because they are very hard to find..
« Last Edit: February 19, 2021, 08:42:20 AM by 754 »
Online 69cb750
« Reply #2 on: February 19, 2021, 08:49:56 AM »
Yamiya has gold nipples.
So you cannot resist ?
« Reply #4 on: February 19, 2021, 09:48:35 AM »
Thanks for the links, all. I’m definitely trying to keep the bike original. Tank will get some “dent Dr.” But then I plan on scrubbing, polishing and re using all the original “body work”. Having said that, the wheels need help. Bearings, Spokes and tires for sure. I want to ride this thing. Anything that connects my butt to the road is getting done.
Offline Ujeni
« Reply #6 on: February 19, 2021, 11:02:15 AM »
Original spokes were steel with a clear zinc plating on them that gave a very slight blue tint. The spoke nipples were also steel with zinc...but it was a yellow zinc. You can always add a yellow chromate to any clear-zinced part you buy with this:
https://caswellplating.com/yellow-chromate.html
Ujeni Motors
Sandcast #410
Sandcast #538 Watch the restoration!
Sandcast #6592 All original daily driver.
« Reply #7 on: February 19, 2021, 11:10:41 AM »
Caswell for the win! I may do that myself.
« Reply #8 on: February 19, 2021, 12:22:37 PM »
Which models had yellow nipples?
I did not have that in my mind when I replaced both rims with spokes on my K6 early 80's.
My K2 build got the spokes with yellow nipples from Germany. I thought that was the original look.
« Reply #9 on: February 19, 2021, 06:28:42 PM »
Apparently the Sandcast needs to have yellow cad nipples.....
Offline Ujeni
« Reply #10 on: February 19, 2021, 07:21:28 PM »
Not cad. Zinc. At least thats how all of the sandcasts I have owned have been. I think Honda started using cad plating in the early 80s.
« Last Edit: February 19, 2021, 07:24:34 PM by Ujeni »
Ujeni Motors
Sandcast #410
« Reply #11 on: February 19, 2021, 09:09:11 PM »
Sam..... My mistake. Thanks for the correction. In my research, I watched and read about the restoration of #538. Truly outstanding work! Yourlast picture reminded me of my first and only visit to a  concours event. Mr. Hooker was there too!
« Last Edit: February 19, 2021, 09:18:54 PM by BenelliSEI »
Offline jamesw
« Reply #12 on: February 20, 2021, 11:37:26 PM »
Vintagecb750.com sells spoke kits with gold nipples.
Alternatively, you could get the originals replated in yellow gold zinc Scarborough by H & E Plating. They just did a batch for me (bright silver for my batch).
« Last Edit: February 20, 2021, 11:39:24 PM by jamesw »
72K-F 750 Cafe
75K 750 Cafe
75F 750 Restoration
« Reply #13 on: February 21, 2021, 05:37:07 AM »
James.....I’ll check again, I thought their CB750 Spokes were all silver? Thanks!
« Last Edit: February 21, 2021, 08:50:57 AM by BenelliSEI »
Offline jamesw
« Reply #14 on: February 21, 2021, 11:36:54 AM »
The ones I got for my 75F have gold nipples.
The plating route is also an option but it would much more expensive because the minimum charge is $150, and you probably couldn't find enough pieces that require the yellow plating to make it cost worthy.
It was for me because I got my pieces plated in silver zinc
72K-F 750 Cafe
75K 750 Cafe
75F 750 Restoration
« Reply #15 on: February 21, 2021, 01:12:13 PM »
I’ll go with PeWe’s suggestion....
Offline JamesH
« Reply #16 on: February 21, 2021, 01:35:46 PM »
The spoke sets from Germany are really nice quality. The zinc finish on the spokes are beautiful (very shiny/bling). Just be warned, the nipples aren't identical to the OEM Honda items. They're missing the additional ‘top hat/nipple’ where the spoke enters the nipple. So for a bike lil you're sandie personally I’d get the original nipples / spokes related and the nipplea gold passivated.
Sent from my iPhone using Tapatalk Pro
« Reply #17 on: February 22, 2021, 12:48:44 AM »
« Reply #18 on: February 26, 2021, 02:53:10 PM »
cb750.com front spoke nipples for a 750 a are gold and have the correct shape. at $40 a set  not so bad, they come with a washer for the aluminum rim. Can't say for sure about the length of the spokes.
https://www.vintagecb750.com/parts/480/73-0174.jpg
Offline Ujeni
« Reply #19 on: February 26, 2021, 03:11:10 PM »
Ha! Thanks very much! And congrats to you too!
Ujeni Motors
Sandcast #410
« Reply #20 on: March 02, 2021, 05:14:58 PM »
 Caswell has the yellow chromate converter for $35 a bottle. Now I want to find the correct shape.  It appears the cb750A and gl1000 spokes are a different part number so length is a question, I don't think the aluminum hub is dropped center like the steel ones are.
« Reply #21 on: March 02, 2021, 06:06:05 PM »
Don..... let me know if that Caswell product does the job.
A few years ago, I bought several bikes at once. Lots of parts came with the deal. I went through the spoke bin today, and found what I need!!
« Last Edit: March 02, 2021, 08:13:59 PM by BenelliSEI »
Offline Ujeni
« Reply #22 on: March 02, 2021, 06:53:30 PM »
Looks like Yamiya's kit now has yellow zinc:
https://www.yamiya750.com/index.php?main_page=product_info&cPath=246_251_184_87&products_id=3036
Ive used these in my restorations. Super close to the originals.
Ujeni Motors
Sandcast #410
« Reply #23 on: March 02, 2021, 07:48:23 PM »
 Yamiya's look like the ones I've used except they lack the rounded end. I was hoping to find oem appearance but even newer Honda spokes aren't sandcast correct.
  I need to dig through the K0 totes myself. I'm sure I bought a full set last time and have one or another end left, Sandcast style nipples too.
Offline Kevnz
« Reply #24 on: March 02, 2021, 09:23:14 PM »
Are these the same item. Off a 500. Probably should be zinc? $150 for the replating, cheaper than 2 sets of spokes.
Good grammar: The difference between knowing your #$%* and knowing you're #$%*
