Author Topic: 1975 Amen Chopper  (Read 39409 times)
Offline Shtonecb500
    • Youtube profile
Re: 1975 Amen Chopper
« Reply #275 on: June 02, 2021, 02:17:04 PM »
Lovin’ It!
I like your handle bars.
bike looks dope, get those videos up and let us know how it rides at 60mph!
 can we organize  chopper meet up!?
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline BenelliSEI
  • 1969 cb750
« Reply #276 on: June 02, 2021, 02:19:38 PM »
I rode it today and it worked perfectly. Buddy took a video, but can’t seem to post it! Pictures tomorrow. Motor has tons of torque and pulls like a freight train. Very loud on the FUBAR straight pipes. 60-65 psi oil pressure and idles beautifully. Front disc is just touching the caliper mount, will have to add a very thin shim to the axle spacer on that side. Otherwise, total success. Turning at low speed takes some concentration. The front wheel wants to “fall over” and turn hard, so a significant amount of “hold” is required. I suspect this improves with speed.....
May have to “borrow” the plate and paperwork from my red K1 and take it for a slightly longer run on the side roads around the farm. Really enjoying this contraptions!
my wheel sits out really far and yeah at speed its better to do anything, getting stuck in rush hour is the absolute worst...I rather turn my bike off and come get it later at night if I get caught in a traffic jam.  My riding style is very very different on the chop, it's very "cowboy" I would say. I'm doing a lot of feathering and coasting to avoid the harsh stand still and hold the wheel up straight. I had a 17inch hallcraft on mine and installed a cl350 front wheel, gave me a larger 19" wheel, doesn't fall over as much and easier to balance. Aesthetically speaking, the 17 inch wheel up front looked better, it was sleeker and sexier, but that brake in that hub couldn't stop itself from rolling down a hill. Im considering lacing a 17" inch rim to the cl hub to get my proportions back in line.
This one has a 21” front wheel and I really have to “hold it up” at low speed.
Offline BenelliSEI
  • 1969 cb750
« Reply #277 on: June 02, 2021, 02:21:04 PM »
High speed trial hasn’t happened yet......
Offline BenelliSEI
  • 1969 cb750
« Reply #278 on: June 02, 2021, 02:22:15 PM »
Lovin’ It!
Those are are stock ‘69/70 CB750!
Offline Shtonecb500
    • Youtube profile
« Reply #279 on: June 02, 2021, 04:46:42 PM »
Lovin’ It!
you blew my mind, Im going to swap some in tomorrow.
Offline BenelliSEI
  • 1969 cb750
« Reply #280 on: June 02, 2021, 04:48:48 PM »
Another picture
Offline BenelliSEI
  • 1969 cb750
« Reply #281 on: June 02, 2021, 04:50:05 PM »
Big files.....
Offline BenelliSEI
  • 1969 cb750
« Reply #282 on: June 02, 2021, 04:51:18 PM »
Back end
Offline BenelliSEI
  • 1969 cb750
« Reply #283 on: June 02, 2021, 04:52:22 PM »
21” front wheel
Offline BenelliSEI
  • 1969 cb750
« Reply #284 on: June 02, 2021, 04:56:05 PM »
Last one!
« Reply #285 on: June 02, 2021, 06:35:33 PM »
Handling issues  often are related to the amount of trail you have.
 I will warn you about a common issue with girders....a few things.
 The links that go fron triple tree to girder shoukd all be tge same length.
 And they shoukd ge roughly parallel, top and bottom.
 Some folks thank that the length of these  are an adjustment, and may make new ones with different length between holes than original.  Sometimes its because the bike has wrong length girder, or you just want itto sit a certain way. This can lead to probkems like flop and evil handling...... and choppers dont need to be tbat way.
 This is part of why some have dertain problems and other do not.
 Long rake  will always feel a bit weird at low speed, once you get over 15 mph, probably wont notice much... and  you get used to it..
Offline BenelliSEI
  • 1969 cb750
« Reply #286 on: June 02, 2021, 07:50:51 PM »
Frank..... I checked the dimensions you suggested. Two halves are parallel and all the pivot dimensions and over all length are identical. To your point, I have only done some low speed runs on the hard pack road, just outside our farm gate.
The plan is to sneak out one weekday morning and visit a good, long (usually lonely) stretch of smooth paved road, just north of us. It also just occurred to me I never lubricated all the pivot points on the girder links. Every one of them has a grease nipple on the underside of the link bars. Next task.
« Last Edit: June 02, 2021, 07:57:36 PM by BenelliSEI »
Offline Shtonecb500
    • Youtube profile
« Reply #287 on: June 02, 2021, 08:19:13 PM »
I wonder if we have the same maker for the girder, only difference is the round tube/bar versus my square bar. same kind of links and dual spring...idk who makes mine, i dont even know what kind of rigid frame i have.
Offline BenelliSEI
  • 1969 cb750
« Reply #288 on: June 03, 2021, 06:14:35 AM »
Shtonecb550..... I was lucky to meet the original owner/builder (I’m only the 2nd owner), so got all the information from him. Have you tried the chopper group on Facebook? They may help you.
Offline BenelliSEI
  • 1969 cb750
« Reply #289 on: June 03, 2021, 05:24:10 PM »
Pulled off the ugly in line gas filters I started on. New black hose installed Greased all the pivot points on the front and and then stared at it for 10 minutes. Other than finding a pair of mirrors that will suit it, I’m totally DONE.
« Reply #290 on: June 03, 2021, 06:25:38 PM »
 Shop motorcycle mirrors on ebay and there are more than you care to look at.
Offline BenelliSEI
  • 1969 cb750
« Reply #291 on: June 04, 2021, 05:27:39 AM »
I looked at 100’s! Still not seeing what I want. Something low, small and chrome...... also don’t want to wait 8-10 weeks.........
« Reply #292 on: June 04, 2021, 08:40:19 PM »
 Take a stock 750 mirror, shorten stem and rethread, mount on master cylinder, one mirror will be fine..
« Last Edit: June 04, 2021, 08:42:24 PM by 754 »
Offline Alan F.
« Reply #293 on: June 04, 2021, 08:45:24 PM »
Perhaps this?
https://www.revzilla.com/motorcycle/bike-master-old-school-tube-mirrors?gclid=Cj0KCQjwnueFBhChARIsAPu3YkSy5_0R0Z0SRPKGZxc7Fm4Fc-mnmF3lR3mUPgs7-QmFZ_bPhaAxFvUaApcUEALw_wcB
It's a terrible video, but this guy has these mirrors on a late model CB1100. While he's riding you can get a good idea of how good a view these mirrors give, very crisp and clear without buzzy vibration making them blurry. Not particularly cheap though but good quality.
« Last Edit: June 04, 2021, 09:00:06 PM by Alan F. »
« Reply #294 on: June 04, 2021, 11:00:31 PM »
Offline BenelliSEI
  • 1969 cb750
« Reply #295 on: June 05, 2021, 05:18:38 AM »
All good suggestions! Thanks.
« Reply #296 on: June 07, 2021, 12:50:56 PM »
Just an observation... meant in a nice way..
 You have a guy restores bikes, you have little choices.. it has to look original..  choice of one look..
 Then he gets a chopper.. now you got UNLIMITED Choices..... now cant make up their mind and pick one.... lol..
 Yeah i know shipping is a pain, but throw a dang mirrir on and break your Chopoer Cherry...... already...
Offline Alan F.
« Reply #297 on: June 07, 2021, 02:02:37 PM »
This is why I can't have nice things.  ::)
Except Frank's frame kits, they're nice and I have one.
Edit: added eyes averted emogie
« Last Edit: June 07, 2021, 02:04:28 PM by Alan F. »
Offline BenelliSEI
  • 1969 cb750
« Reply #298 on: June 07, 2021, 05:06:19 PM »
Frank..... you made me laugh out loud. I pulled out my junk mirror box and picked one. Done.
P.S. I still want a pair of iron cross mirrors!
« Reply #299 on: June 08, 2021, 12:21:10 AM »
....until I try to see anything in those iron cross mirrors with a glance and can't...
