Author Topic: 1975 Amen Chopper  (Read 28977 times)
Re: 1975 Amen Chopper
« Reply #325 on: February 27, 2023, 02:44:50 PM »
Nice find. I’d close it down and use a spray wax.....
Offline chiefum
« Reply #326 on: March 03, 2023, 02:06:12 PM »
Removed and replaced the seal behind the front sprocket. It looks like the cases were damaged and repaired years ago. Looks like weld and some sort of bondo/epoxy was used. It looks pretty good, except for a crack up near the top, where I was able to insert a small wire into the cases. Is there an epoxy or jb weld that I can use just over the crack? I've never used jb weld or anything on an oily surface,  how clean does the area have to be?   I'm looking for opinions on how to proceed,  I'll search the forum and see what I can find.
Sent from my SM-S908U using Tapatalk
« Reply #327 on: March 03, 2023, 03:17:23 PM »
Ouch.... never saw that. Take a Dremel tool with a smal, conical bit. Grind a shallow “V” in the crack there. Clean really well with spray brake cleaner. I use the JBWeld that comes in two tubes, base and hardener. Mix them really well, 50/50, and apply with a small, flat applicator. Very good stiff.
Offline chiefum
« Reply #328 on: March 03, 2023, 03:56:32 PM »
Thanks, I will give that a shot.
« Reply #329 on: March 03, 2023, 04:35:53 PM »
I was just looking at that seal on my s/c project. Is that a drywall screw you drove into the seal? I usually change those when I split the cases, but will give it a try.
Offline chiefum
« Reply #330 on: March 03, 2023, 05:02:13 PM »
I believe it's called a lath screw. It has a panhead, it was just what I had on hand, but it worked great. I wrapped packaging tape around the shaft, slid the seal on, and used a 2 inch pvc pipe with a cap to pound the seal in place.
« Last Edit: March 03, 2023, 05:08:25 PM by chiefum »
« Reply #331 on: March 03, 2023, 06:48:01 PM »
Sounds good, will give it a go.
Online newday777
« Reply #332 on: March 04, 2023, 03:02:28 AM »
One of the bikes oil leaks was coming from the shifter/kickstand area. I ordered new a new chain and sprockets and found this front sprocket, I've ordered stock replacement parts and I'll swap them out. I pulled the front sprocket off and it looks like it's missing the rubber orifice altogether.  What are people doing to eliminate the chain oiler? I'll have to come up with something.
There are a few posts on plugs that owners made to fit the hole to stop the oil flow using the plug with an O-ring.
http://forums.sohc4.net/index.php?topic=190264.0
Joker machine sells a plug, though I wouldn't fill the insides completely with RTV as they say in their instructions. I haven't bought one to know how tight their plug fits in the hole.
https://jokermachine.com/products/cb750-chain-oiler-plug
Online newday777
« Reply #333 on: March 04, 2023, 03:18:19 AM »
And here's a warning on too much sealant.
http://forums.sohc4.net/index.php/topic,189481.new.html#new
Scottly posted he made a threaded plug near the end of that thread.
Offline chiefum
« Reply #334 on: March 04, 2023, 05:14:40 AM »
Thanks for sharing that thread, I hadn't seen that one in my searching.  I have sourced a good rubber orifice,  so I guess I'll be using that until some one makes something similar to what Frank had made.
Online newday777
« Reply #335 on: March 04, 2023, 05:32:00 AM »
Make sure the rubber is still pliable.
Offline C317414
« Reply #336 on: March 04, 2023, 01:31:51 PM »
I've used a screw a few times, but most of the time I use a sharp punch to poke a hole through.  Then I use a tool pick to pry it out.
« Reply #337 on: March 06, 2023, 04:35:37 PM »
Thanks. Got it out today.
Offline chiefum
« Reply #338 on: March 06, 2023, 04:40:24 PM »
Nice!! Easy, peasy.
« Reply #339 on: May 04, 2023, 11:31:01 AM »
Been for a ride yet??
Offline chiefum
« Reply #340 on: May 04, 2023, 11:55:43 AM »
Not yet. I've still got to change the oil pan gasket,  degrease the engine, and finish cleaning out the carbs. When pulled the carbs, I found some slight clogging of a jet, hard o rings, and a jet with the mikuni logo and three without. I'm currently waiting on a delivery from jetsrus. Hope to set the carbs up possibly this weekend and replace the oil pan gasket too.
Offline chiefum
« Reply #341 on: May 04, 2023, 12:14:40 PM »
I'm wondering if there are clip positions to adjust, seems to be rich. I haven't had a chance to check float height yet, I was waiting for the jets and o rings.
« Last Edit: May 04, 2023, 01:19:39 PM by chiefum »
« Reply #342 on: May 04, 2023, 03:11:08 PM »
It must have had some miles put on it. It was spotless when I sent it off. Good luck!
« Reply #343 on: May 30, 2023, 04:01:35 PM »
Traded emails with Chiefum today and he is making progress. Hopefully there will be more pictures?
Offline chiefum
« Reply #344 on: May 30, 2023, 05:15:56 PM »
I'll see if I can find some pics. This week work is busy, but I'm hoping to fire it up this weekend.
« Reply #345 on: May 30, 2023, 07:48:08 PM »
Great! I’ll interested to hear your comments on “first ride”. I’d never ridden anything even remotely like that bike and it was a hoot!
« Reply #346 on: September 14, 2023, 05:55:55 AM »
Curious how that first ride went? Any news??
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #347 on: October 31, 2023, 08:11:53 AM »
Late to the party but following.
I recently picked up a ,77 750 in a savior frame.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
Offline chiefum
« Reply #348 on: October 31, 2023, 12:35:10 PM »
Awesome! Any pics to share? I sent the engine up to Cycle X, hoping to have this one buttoned up in spring.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #349 on: October 31, 2023, 01:51:27 PM »
Don't want to highjack this thread with my junk. I'll start a thread for it when I get it on the lift !
