Author Topic: CB750 K0 shift drum doesn't seat  (Read 3025 times)
Offline jebon
« on: March 04, 2021, 11:51:17 AM »
Hi!
I can't get my shift drum to seat all the way in and also have the neutral switch in and engage at the same time. Do I have a wrong shift drum for this case? I'd be surprised if this is the way it's supposed to sit
"Don't let schooling interfere with your education"
CB750 K0 1971
Re: CB750 K0 shift drum doesn't seat
« Reply #1 on: March 04, 2021, 12:00:12 PM »
You have to be assembling something not quite right
Offline jebon
« Reply #2 on: March 04, 2021, 12:55:44 PM »
If I take out the neutral switch, then I can put it in all the way but the end of the drum blocks the hole for the switch. Could it be the switch or the drum that's wrong?
CB750 K0 1971
« Reply #3 on: March 04, 2021, 01:08:20 PM »
Chances are the spring loaded ball in the neutral switch is not perfectly engaging the shift drum. Loosen the neutral switch and wiggle the basket thingy in your picture in and out to see if it will seat.
Offline jebon
« Reply #4 on: March 04, 2021, 02:31:33 PM »
For the drum to sit right the neutral switch needs to sit at this height. But then it won't line up for the flat sided washer below. And there's a gap between the case and the switch. Is this just supposed to be squeezed tight?
CB750 K0 1971
« Reply #5 on: March 04, 2021, 03:48:46 PM »
The Neutral Switch must be seated, or else you'll have both an oily mess and the upper gears in the tranny will jam when shifting, misaligned.
The shifter drum does not fit flush to the inside bearing hole. If you have a late shifter drum in an early case, the shoulder of the drum will sit higher than you were used to seeing with the early shift drum (near the shift end, where the little pins and cover live). This shoulder is wider on the later drums.
If you have K0 cases and are fitting a later shift drum, the later drum may not fit because the K0 spring arm detent system is different from the later ones: sometimes the little rollers on the sprung levers will not sit at the right height. The shift drums from the K6/F0 and later bikes don't fit into the K0 cases well, if at all, and vice-versa, because the case wall got thicker during the K1 engine, and the shifter drum, while a 'delta part' design, wasn't quite a 100% replacement fit.
Offline BPellerine
« Reply #6 on: March 04, 2021, 04:51:44 PM »
did the drum come out of this engine?
1978 CB 750K ard and webers
another anfob
Offline flybackwards
« Reply #7 on: March 04, 2021, 06:45:24 PM »
FYI - this is the way mine sat in my K7 prior to taking it apart - so as the Hondaman says it does not sit flush
Offline jebon
« Reply #8 on: March 04, 2021, 11:25:30 PM »
Thanks, yes that's what I thought.
CB750 K0 1971
Offline jebon
« Reply #9 on: March 04, 2021, 11:26:49 PM »
Everything came from this engine when I disassembled it. I did not take note that anything fit poorly when I took it apart. But this drum clearly doesn't fit the case.
CB750 K0 1971
Offline jebon
« Reply #10 on: March 04, 2021, 11:46:52 PM »
If the switch is to be flush below then it has to sit this high. It could be lower depending on the O-ring size. But I need the correct drum for the case
CB750 K0 1971
Offline jebon
« Reply #11 on: March 04, 2021, 11:49:15 PM »
... Also it seems from the marks on the drum that it been sitting wrong
CB750 K0 1971
Offline jebon
« Reply #12 on: March 05, 2021, 12:03:24 AM »
So if I find the correct drum, there's a chance I also need to source the rest of the shifter mechanism - or some of it?
CB750 K0 1971
Offline jebon
« Reply #13 on: March 05, 2021, 12:35:19 AM »
CMSNL has an alternative view with the star shaped plate. Is this maybe the one I need? There's one on ebay now.
https://www.ebay.de/itm/1970-HONDA-CB750-K0-SHIFT-DRUM-/264388921444?_trksid=p2349624.m46890.l49292
CB750 K0 1971
Offline 69cb750
« Reply #14 on: March 05, 2021, 06:10:33 AM »
24301-300-030 was used on K0,K1
24301-300-040 was used on K2
The shifter drum changed in 72, not sure what changed, someone here may know.
There is a K1 drum on ebay - https://www.ebay.com/itm/1971-Honda-CB750-K1-ENGINE-TRANSMISSION-GEAR-SHIFT-SHIFTER-CAM-DRUM/174541549891?hash=item28a37cb143:g:jPkAAOSwKc5drIqi
Offline BPellerine
« Reply #15 on: March 05, 2021, 06:18:38 AM »
I thought the shifting improved on later bikes,that was the only change,some mention in hondamans book
another anfob
« Reply #16 on: March 05, 2021, 06:26:54 AM »
Using the info available on the documents section of this forum and the on-line sources such as CMS check your part numbers carefully to see when and how they changed otherwise it s a gamble buying stuff.
Offline jebon
« Reply #17 on: March 05, 2021, 07:06:29 AM »
After browsing a great deal I haven't seen any that looks to have a narrower flange. They all look very much like mine. Even if they state K0 or K1. One on ebay even has the engine number listed (in the 10,000's I believe) I've asked a few on ebay and CMS to measure the flange.
I'm beginning to fear what else is not original on this bike. I hope not the cam shaft etc.
CB750 K0 1971
Offline 69cb750
« Reply #18 on: March 05, 2021, 07:18:30 AM »
Your flange is 16.30 mm ?
Report the flange info you receive.
I suspect it is the crankshaft and some of the main bearings.
You should file suit against all the previous owners and demand huge sums of money !
Offline 69cb750
« Reply #19 on: March 05, 2021, 07:25:39 AM »
Offline 69cb750
« Reply #20 on: March 05, 2021, 07:26:27 AM »
Offline jebon
« Reply #21 on: March 05, 2021, 02:15:56 PM »
After trying it again I'm maybe leaning towards that I may have the right part. Either that or the correct drum is a very rare part. I was able to assemble it. But it has a gap at the end of the drum inside the case.
However, I am not overwhelmed by its willingness to shift properly. I don't know if this will improve when the upper gears are fixed by the uppercase and the clutch. It sometimes just gets stuck and even jams when trying to go into 5th. I'll try a test fitting with the upper case tomorrow.
CB750 K0 1971
« Reply #22 on: March 05, 2021, 02:22:50 PM »
Both shafts have to rotate to shift gears
Offline jebon
« Reply #23 on: March 05, 2021, 02:29:17 PM »
I'm not sure I know what you mean. I'm rotating the upper which is engaging with the lower.
CB750 K0 1971
« Reply #24 on: March 05, 2021, 05:43:55 PM »
Not all the gears turn when you totate one shaft so the "dogs" can but up againsta solid instead of a hole, whentrying to shift rotate the other shaft slightlyand the gear usually drops in. In use the only time a shaft is not moving is at standstill and you only go into 1st from that
