Author Topic: Identifing genuine Keihin float needle valves vs reproductions?  (Read 794 times)
Offline fizzlebottom
Is there any clear cut way to tell the difference? Like if you had a handful of mixed genuine and repro needle valves and wanted to put them in various bins, how would you tell?
« Last Edit: March 09, 2021, 11:42:34 AM by fizzlebottom »
1982 CB650SC Nighthawk
2024 Kawasaki Z900RS
Offline goodtryer
Re: Identifing genuine Keihin float needles vs reproductions?
« Reply #1 on: March 09, 2021, 11:07:48 AM »
Keihin are stamped with the name and the stylized K logo on the ones I have seen.
"Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles."
-Dostoievski
1977 CB550K
1978 CB750K
1973 CB500K
« Reply #2 on: March 09, 2021, 11:43:13 AM »
That looks like valve seat. What about the needle valve itself?
Re: Identifing genuine Keihin float needle valves vs reproductions?
« Reply #3 on: March 09, 2021, 06:57:28 PM »
That's a picture of a mainjet.
The Kehin float valves have soft springs in them. The modern ones since about 2002 or so have MUCH stronger springs. They can work OK, provided you set the floats deeper when installing the new, stiffer ones. I usually set the CB750 floats, which are 26mm with Keihin's float valves, to 24.5 mm if brass or 25mm if plastic.
