Author Topic: CB750K Hub Dampers  (Read 895 times)
Offline Maltboy
  • Pitter-patter, let's git at 'er!
  • Making stupid mistakes since 1959
CB750K Hub Dampers
« on: March 28, 2021, 07:54:20 AM »
Assembling rear wheel of my 750K5 -  Do I need to use any lubricant on the rear hub dampers?  Seems like it might need some to reduce wear. If yes, what is the best kind to use?
Offline 69cb750
Re: CB750K Hub Dampers
« Reply #1 on: March 28, 2021, 08:18:45 AM »
No, raw rubber
Offline Maltboy
« Reply #2 on: March 28, 2021, 09:34:44 AM »
Thanks.
Online PeWe
« Reply #3 on: March 28, 2021, 12:26:37 PM »
Lube can be needed to get the sprocket carrier to enter the tight rubber filled areas.
Last time tire mounting grease and still need force to get the carrier to dock completely so wheel could fit the swingarm.
Offline Maltboy
« Reply #4 on: March 28, 2021, 01:44:59 PM »
That's exactly the problem with this hub. Just a little silicone grease on the sprocket carrier to get to slide in wouldn't hurt, right?  ;)
« Last Edit: March 28, 2021, 01:46:51 PM by Maltboy »
Online PeWe
« Reply #5 on: March 28, 2021, 10:16:05 PM »
I'm not sure about silicone grease on rubber.
Soft soap will not age the rubber. Or dish soap.
Offline caluser2000
« Reply #6 on: March 28, 2021, 11:10:59 PM »
A little CRC 5..56 will do the job without affecting the rubber.
i've been using it for over 20years to install tires on steel m/c rims by hand using tire levers.
« Last Edit: March 28, 2021, 11:17:16 PM by caluser2000 »
Every time you set your ass on a bike, you're playing a game of Russian Roulette between yourself and your own stupidity."
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #7 on: March 29, 2021, 12:56:44 AM »
Yeah in this case simple works.  Dawn dish soap.
I recently restored and sold a 77 cb750f, and am nearly finished with a (former basket case) cb750k5.  This is a place to share, learn and enjoy.  I am grateful to and for 99+% of this site's membership.
Offline Maltboy
« Reply #8 on: March 30, 2021, 05:44:19 AM »
Thanks all!  I used some Dawn dish soap and it worked like a charm.  It also worked on a stubborn rear tire that I couldn't get to seat.
